Old 02-03-2019, 08:41 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Refrigerator drain line clogged
What is the best way to free up a clog in the refrigerator drain line ??? Condensation tray fills up and drips inside and puddles on the floor and needs to be sopped up. I tried to run a flexible wire up from the bottom with no luck so now looking to see how others have managed to clear the drain.
ThanX all.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 02-03-2019, 08:53 AM   #2
2012 28' International
Prince Edward County , Ontario
We have had a similar problem however the blockage was in the drip tray itself. The spout where the tray drains into the line becomes blocked. We removed the drip tray and cleared the blockage.
Cyclist is offline   Reply With Quote
Old 02-03-2019, 09:25 AM   #3
Tuco's Avatar
1988 32' Excella
Ojai , California
Pull the tray and line out, clean it then reinstall.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 02-04-2019, 07:07 PM   #4
retired USA/USAF
2001 30' Excella
The tray has been out and cleaned. The water backs up in the small outlet that the drip tray drips into. Somewhere downstream there's a blockage in the hose causing the backup.
Roger in NJ
TAC - NJ 18
Old 02-04-2019, 07:52 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Do you not have an access door on the exterior for the refer? Both our trailers have full access to this line and the 2011 I needed to replace it due to it disintegrating.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-07-2019, 07:32 AM   #6
retired USA/USAF
2001 30' Excella
Thanks Alan. I do have the access and need to look closer at that for a possible solution.
Roger in NJ
TAC - NJ 18
Old 03-02-2019, 07:26 AM   #7
retired USA/USAF
2001 30' Excella
Now that I've looked for the drain line AND have an internet connection to reply I should note that the drain line seems to NOT be accessed through the refer access panel. I just don't see it. I did get a flexable but stiff wire and attempted to pass it up from the outlet with no luck. The drain is a semi-rigid white plastic tube exiting just forward of the wheels, drivers side, and seems to have a hard obstruction about 6-8" up the tube. I haven't yet, but plan to, try to blow it out with a compressor. So still blocked up here.
Roger in NJ
TAC - NJ 18
Old 03-02-2019, 08:13 AM   #8
dznf0g's Avatar
Oswego , Illinois
I believe your layout may be similar to mine. The white pex drain portion from the floor of the fridge compartment..starting from top...goes down to the top of the wheel well, makes a 90* turn to side of wheel where it makes another 90*, and another 90* turn to run a along the floor for about a foot, then makes another 90* turn through the floor and under the trailer. So the fact you hit a hard stop when probing from underneath is absolutely normal.
If you have access under the fridge pedestal (a drawer in my unit) remove it and you will see the drain tube.
If yours is pex, it can stand >50 psi of air pressure. I'd soak by pouring water from top. Let stand for quite a while and blow out with compressed air.
-Rich-
Old 03-02-2019, 08:31 AM   #9
dznf0g's Avatar
Oswego , Illinois
Pic from top, inside fridge compartment
Name:	Fridge drain 4.jpg
Pic from under fridge pedestal after drawer removal
Name:	Fridge drain 5.jpg
Pic (in wood cutout) from under rear dinette seat
Name:	Fridge drain 3.jpg
Pic under trailer of drain termination
Name:	Fridge drain 6.jpg
-Rich-
Old 03-22-2019, 08:46 AM   #10
retired USA/USAF
2001 30' Excella
Found it. Yeah, it was there I just needed to put my glasses on. Found it and cleared it so all's well. Thanks all for the information
Roger in NJ
TAC - NJ 18
Clogged shower drain Jamesbford 2016 - Current Flying Cloud 3 10-13-2018 09:35 AM
Dometic refrigerator drain hose clogged ExStreamin Our Community 1 10-23-2017 09:10 PM
Clogged Shower Drain on MH comprose Plumbing - Systems & Fixtures 4 09-18-2015 03:05 PM
Broken or clogged A/C drain line danjoe91 General Repair Forum 5 05-13-2013 09:01 PM
Help! Yucky clogged shower drain Blu_Hwy_Lady Waste Systems, Tanks & Totes 25 05-10-2006 01:07 PM
