1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Refrigerator blues
How old is your working refrigerator? I bought a new Dometic and thought I was good and careful, (only using it when it's level) and it was great . It only lasted 5 years. Is there a better fridge out there? I need to buy 2, one for the motor home and one for our "new" 73 globetrotter. What can I do to keep it working? Please help, any advice or even a little sympathy might help.
Bibbs
Do you know what is wrong with the refer(s)?
Have you lost the ammonia charge?
Does it (they) work on electric or propane? One or the other.
What are the symptoms?
Have you done anything with the control board(s)? There won't be one in the '73 unless the refer is not original. Don't know what is in the MH.
I have a 42 year old Dometic refer that still works. You may have the same refer in your '73.
Unless you have lost the ammonia which requires a cooling system replacement. Most other problems can be resolved much cheaper than a new refer.
Unlike GM+DuPont's 'Frigidaire', Albert Einstein's ammonia system will heal if turned over.
This will kill a 1,1,1,2-tetrafluoroethane 'Freon' type device.
My 1973 Dometic still cools as it should. I have replaced the electric element twice in my 15 years of ownership and I blow out the burner tube yearly with compressed air.
1975 26' Argosy 26
Vista
Yes the 73 is original the gas makes a flame that stayed on and or the electric makes the flue hot, to the touch. The flue is clean, nothing gets cold.
The MH Dometic was new in 08, I tried a new control board, no difference. Never smelled amonia. I will try unplugging the thermistor, I read that will make it run continuously.Yeah bad luck, with refrigerators, lucky with almost everything else
I hope
