Old 07-06-2008, 07:40 AM   #1
1983 31' Excella
Carbondale , colorado
Refrigerator alarm?
On the control panel there is a light on that says "Refrigerator alarm". I am plugged in and the light is on. Does this mean something is not working? The fridge seems to be working though it is either to cold or not cold enough. I can't seem to find any mention of it either the owner's manual or service manual.
Peter
1983 Excella 31 mid bath
Yak dad is offline   Reply With Quote
Old 07-06-2008, 07:49 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Hmm.... Hopefully Lewster will look in on this thread, but I think it shows a fault in the system, and the fridge is operating in "limp" mode. It could be that you are low or out of LP, have you checked that?
Old 07-06-2008, 10:56 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Peter
Hi Peter,
If possible, I would like to see a photo. I can find nothing 1883 Excella's System Monitor that refers to the refrigerator. Mine (the refrigerator) is dead, too, so if there was one to should be on. I have a new one to put in as soon as a Snyder vent kit gets in.
Vaughan
Old 07-07-2008, 07:44 PM   #4
wlj1943's Avatar
1970 18' Caravel
Mulino , Oregon
Hi Peter,
I think Overlander is on the right track; I once serviced a 1980's vintage AS motorhome that I remember had this optional alarm, (only one I remember seeing) but it may have been an added-on aftermarket device. Since this was about 1987, my memory is foggy. Assuming you have the original Dometic fridge, you are in the time frame when the first electronic control boards (analog) were appearing. I too hope Lewster will weigh in and give us a technically correct answer, and I also agree; a photo would be very helpful to jog the memory.
Warren
WLJ1943
wlj1943 is offline   Reply With Quote
Old 07-07-2008, 08:19 PM   #5
Groveland , Massachusetts
Our 1982 310 motorhome has this option. I comes on when the fridge temp drops below a certain set point. A buzzer sounds and the light comes on after the sounder silenced by changing the switch position.
classic310 is offline   Reply With Quote
Old 07-07-2008, 10:20 PM   #6
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Check the following are ALL OK: trailer level and plumb, refer has less that a half inch of frost built up, and the exhaust tube is free and clear of spider webs, snake skins, wasp nests, termite colonies and bee hives. Are the refer seals at door all tight? Put a thermometer inside and check to be sure it isn't too hot or cold --- 35 to 37 degrees F. is about right. If so, suspect as mentioned earlier - something is broke and it's defaulted to "limp mode." Then start looking for someone who repairs old refers... :0
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 07-08-2008, 06:45 AM   #7
1983 31' Excella
The temps are fine. It was bugs in the drain tube setting off alarm. Cleaned and the alarm light went off. Here is a picture of the control panel.
Thanks for the help.
Peter
Old 07-09-2008, 08:50 AM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Peter
Hi Peter,
Glad it was that simple! Thanks for the photo, my 1983 Excella doesn't have that.
Vaughan
Smoke Alarm Gunnyusmc General Interior Topics 1 06-17-2008 11:33 AM
LP gas alarm bike 2 eat General Repair Forum 5 01-15-2008 07:14 AM
LP Alarm keeps going off csimingt 1997 Safari 7 10-26-2006 09:00 PM
smoke alarm frederic.c01 Interior Restoration Forum 9 08-06-2004 10:39 PM
Alarm Systems swebster Airstream Motorhome Forums 7 09-14-2003 12:58 PM
