Old 10-10-2017, 12:22 PM   #1
alymorales's Avatar
2005 25' International CCD
Mission Hills , Kansas
refrigerator
I just plugged in my camper and noticed that my refrigerator won't switch over to AC mode. On gas mode only. I turned it on and off several times and the check light isn't coming on. Any ideas?
alymorales is offline   Reply With Quote
Old 10-10-2017, 12:33 PM   #2
Lily&Me's Avatar
Normal , Illinois
Be sure your Auto and On buttons are on...and check your fuses.
Maggie
Old 10-10-2017, 12:44 PM   #3
Rich W's Avatar
I'm In , Kentucky
Check for voltage at the heater outlet
On mine, the plug for the heater that goes into the 120v outlet doesn't make a good connection. It's on my list to replace. Find the plug and spread/squeeze the prongs for a better connection, then see if it switches over. If it does, then you too need to replace the outlet.
If that's not it, then the 120v heater is probably bad. Use an ohmmeter to check for continuity. If it reads open then the heater is bad, replace it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 10-10-2017, 12:52 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Check the refrigerator outside compartment. Make sure the refrigerator is plugged into the outlet. Also check the outlet to make sure that it has power.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-11-2017, 09:29 AM   #5
alymorales's Avatar
Thank you
Old 10-11-2017, 09:32 AM   #6
alymorales's Avatar
I'm not sure if you are referring to the breaker switches or not, but I flipped one of the breakers and that worked. When you mentioned heater, it reminded me of where my Breakers are in my camper. Thanks so much.
Old 10-11-2017, 09:32 AM   #7
alymorales's Avatar
Thank you. It was a breaker
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
Propane/Electric Refrigerator jlh Refrigerators 4 09-19-2005 03:53 PM
Flame out on Refrigerator When Traveling jcanavera 2000 - 2004 Safari 8 12-07-2002 10:44 AM
refrigerator panels eraffety Airstream Motorhome Forums 2 03-31-2002 11:20 PM
