Originally Posted by walter1
[font=Times New Roman][size=3]I’m installing a Dometic RM2551 refrigerator in 64 Safari. ......
The Dometic 2551 is a two way (110 and Gas), requiring a constant
12 volt for ignition and Circuit Board Control - The circuit board at the back of the Dometic will have a "terminal board" for screw tightening both the
12 volt + and - leads. It would be best to bring both of these leads directly from the battery terminals, fusing and switching as you deem necessary. If it were mine, I would not ground to a wall or the frame - only directly to the battery terminal.
The 110 connection is just that, a 110 receptical....Special RV recepticals are available at most of the larger RV outlets and catalogs. Be very careful in running the 110 wires and the hookup if you have to install a receptical - special considerations to neutral and ground circuits are necessary for safety.
