Old 02-27-2009, 02:02 PM   #1
1996 25' Excella
Delray Beach , Florida
Smile refrig will not light on propane
I have a 95 excella 25 classic and the frig works well on electric(11ov) but will not light on propane. I hear the electric ignition trying but no light. dometic royale rm3662, freezer on top separate door. Would any of u kind folks have any ideas to get it running? Thank u
kimbal88 is offline   Reply With Quote
Old 02-27-2009, 02:18 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Remove the cover from the burner area and have someone attempt to light the ref. You should see or rear the igniter sparking against the burner.
If you do not have a spark you may have a bad board or coil.
If you are see or hearing a spark and the burner still will not light you may have air in the gas line and the pilot valve can not bleed it off. Crack the gas line at the ref. just long enough to smell gas and tighten it down and try again.
If you have gas and spark but the resulting flame is poor in shape or colored mostly yellow rather than blue you most likely have a spider in the burner tube. Remover the burner tube and clean it.
Odds are it is one of the last 2 comments as apposed to a bad electrical component.
2004 Excursion 4x4
Old 03-01-2009, 03:35 PM   #3
1996 25' Excella
Thank u howie. I tried! bled until gas came out -I pulled the gas solinoid off and there was corrosion on the shaft of the valve where the coil fits around.I read close to 12vat the leads going into the coil.I tried to relight and it lit. the electric ignition kept sparking for 30 sec or so but after that the flame went out. The flame was blue and I thought the prob was solved but no.does anyone have any ideas?? thanks
Old 03-01-2009, 06:33 PM   #4
HowieE's Avatar
Images: 12
There should be a thermocouple probe just above and in the flame. That is the proof of flame and once satisfied holds the gas valve open for continued flame. Make sure the probe is in the flame. Another help might be to loosen the nut that holds the probe in the main gas valve and retighten to insure a good contact.
2004 Excursion 4x4
Dometic propane re-light issue Boondocker Refrigerators 15 02-09-2011 11:47 PM
Do you use your LP refrig while traveling? John Community Polls 19 07-23-2005 09:28 AM
Dometic Refrig Tin Hut Refrigerators 3 07-08-2005 07:00 AM
2 way refrig tandemfish Airstream Motorhome Forums 2 09-17-2004 08:53 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
