Old 10-08-2009, 10:55 AM   #15
Originally Posted by jcanavera View Post
Here's a discussion regarding why rv refrigerators fail. It's written by a service company.
Why They Fail
Jack
Jack.
Thanks for the post.
Most owners refuse to believe that an RV cooling unit can be ruined, "by misuse."
Perhaps, if they read that article, they become believers.
As long as the trailer or motorhome is in motion, running the reefer off level, will not, have any negative effect.
An old rule of thumb, is that when stopping for whatever reason, (lunch, shopping, groceries) with the reefer off level, there are 2 things to keep in mind.
1. You have about 30 minutes to move the coach, without causing a problem.
2. If the stop is over 30 minutes, either turn the reefer off, or turn down the thermostat.
Also, the hotter the ambient temperature, the more critical the level becomes.
Help refrig failed tsunami Refrigerators 2 07-15-2009 06:52 PM
Dometic Refrig Garages Refrigerators 1 11-16-2006 04:02 AM
2 way refrig tandemfish Airstream Motorhome Forums 2 09-17-2004 08:53 AM
Dometic refrig trio Refrigerators 2 08-12-2003 05:11 AM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
