Old 02-01-2003, 05:43 PM   #1
Question Refrig-how do you remove the shelves?
I went to remove my shelves from the frig, but didn't know how to do it and didn't want to break any of the retainers.
I looked at both manuals, A/S & Dometic, and didn't see any infor on how to remove them.
Could someone be kind enough to share how to do this?
Tks-John
John is offline   Reply With Quote
Old 02-01-2003, 06:00 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
John,
Some of it depends on the age of your refer.
If it is newer there are clips on one side that wedges the shelf between the walls. On the older dometic there should be a little square box that seems to hold the shelf in place against an inner side wall. The center portion of this box can be popped out. The removal of this cover will allow the shelf to slide out. The back side of the box will fall off the wall as the shelf is removed.
Hope this helps.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-01-2003, 06:14 PM   #3
Thanks!
Brett,
I have the small boxes with a cover that encases the shelf siderail.
Do I take a small screwdriver and prey it off?
Do they come off with little force?
Much thanks-john
Old 02-01-2003, 06:18 PM   #4
another question
The shelves have a decent amount of surface rust and I'm wondering what is the best way to clean them up?
Paint? or Replace? or Sand and coat with oil?
Tks-John
Old 02-01-2003, 06:25 PM   #5
Chas's Avatar
Images: 22
I have thought about sanding my fridge shelves and spraying or dipping them in some sort of rubber, kinda like the racks in a dishwasher. I know you can get the rubber stuff in a can for dipping or touching up but haven't really found it in a spray as of yet, maybe bedliner in a can? You might have to worry about too much buildup which would make them not slide in as well.
Chas
Chas is offline   Reply With Quote
Old 02-01-2003, 06:41 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john/chas
may want to consider new, or take them and get them powder coated in your color of your choice.
you will never have to fix 'em again.
or better yet, get 'em chromed!
john
Old 02-01-2003, 06:46 PM   #7
Auto body?
John,
Would a auto body shop do something like that?
Chas idea is cool too if it could be sealed well because I could see rust getting back in if it wasn't totally sealed.
Also, do you just take a screwdriver and pop off those covers that Brett was talking about?
Mac
Old 02-01-2003, 06:52 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john
yes, pop 'em off.
an auto body shop would be able to tell you where to get either chrome or powder coating done.
that or let yer fingers do the walking.
john
Old 02-01-2003, 07:28 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
John ~
We found a place here in Denver called Ajax Custom Plating. We had our door handles and license plate light re-chromed, as I recall it was less than $40 and we were quite pleased with the results. Check your yellow pages for a similar business in your area.
Shari
Old 02-01-2003, 08:10 PM   #10
Thumbs up Nice work
Shari,
Nice job! How would that hold up on the shelves? You know, dragging stuff across it.
I'm looking in the yellow pages and nothing under "plating". Any other suggestions in what to look under?
Tks-John
Old 02-01-2003, 08:15 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Try looking under "chrome", "metal refinishing" "auto restoration".
Unfortunately, the EPA has probably restricted these businesses to near-extinction. Anyplace that restores cars would probably have resources you could tap into.
Good luck!
Shari
Old 02-01-2003, 08:17 PM   #12
I found a local company called "Premier Power Coating & Custom Chrome".
I'll call them Monday and let them tell me which would stand up to everyday useage!
Thanks to all for your input!!
John
Old 02-01-2003, 08:20 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
Good. Glad you found something...I think either powder coating or chrome plating would hold up just fine. That's what's used inside fridges all the time when the shelves aren't glass.
Shari
Old 02-01-2003, 11:51 PM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
nice knobs!
shari
looks like you got a deal!
you are right about the e.p.a. i had my rear crash bar rechromed for my '55 harley.
it was 170 bucks!
small local company, called northern plating. it is a mom and pop outfit.
moral, make sure to ask price. then consider buying new or repo.
john
How do I remove the electric reel? k5cad Airstream Motorhome Forums 6 11-26-2003 06:16 PM
Dometic refrig trio Refrigerators 2 08-12-2003 05:11 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
