Old 08-07-2002, 08:19 AM   #15
Leveling result........
Leveling didn't do anything to improve frig performance, so I guess I'll try fans next.
Question to Pahaska: You mentioned hearing the fans cycle off and on at night. Apparently you have some sort of temperature switch to control them; if so, where and how is it mounted?
roessler is offline   Reply With Quote
Old 08-07-2002, 05:46 PM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Temperature switch
The switch is mounted on the tubing at the end of the finned radiator at the top rear of the fridge. The AS part number is 690394 "Power ventilator, refrigerator". I assume this is the fan and the sensor since the sensor isn't separately listed.
I'm just as happy with the toggle switch inside the trailer that I had on my previous trailers.
John W. Irwin
WBCCI #9632
Do you use your LP refrig while traveling? John Community Polls 19 07-23-2005 09:28 AM
electric floor heating remcolent Floor Finishes 6 11-11-2003 03:12 PM
Dometic refrig trio Refrigerators 2 08-12-2003 05:11 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
