Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-12-2005, 11:45 AM   #15
Turtle's Avatar
Profile:  2004 16' International CCD
Arcata , California
Here is a schematic dtbw sent me. Be sure to cut off the resistors on the fans or they will run too slow if at all. (first attempt at an attachment. Apologies if it doesn't work out)
Turtle is offline   Reply With Quote
Old 06-12-2005, 12:04 PM   #16
Turtle's Avatar
Arcata , California
Hopefully this is a little larger.
Old 06-12-2005, 12:07 PM   #17
Turtle's Avatar
Arcata , California
As for Airstream just putting an on/off switch... Come on! But then we don't get the pleasure and satisfaction of tweaking our trailers do we.
Jamie
Old 06-12-2005, 01:44 PM   #18
rseagle's Avatar
Profile:  2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Here's the link to the other thread related to the noisy frig fan:
http://www.airforums.com/forum...0&page=1&pp=20
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
rseagle is offline   Reply With Quote
Old 06-12-2005, 06:01 PM   #19
Profile:  2005 16' International CCD
Ogden , Utah
Fan Resistors?
I also have changed out the fan on my 05 16' CCD using the info that dtbw sent to me. I located the DPDT switch inside the under sink cabinet next to the refrigerator, so I can switch between off/low/high, as needed, when I check the refer temp.
I do have a question about the resistors on the Silenex fans - my fans each have a cable that goes to a connector. Where are the resistirs located? Can you post a picture that shows what they look like and where to find them? I know what conventional resistors look like, and didn't see anything that looked like that on the fans.
I ran tests to measure cooling capability vs. current (we dry camp a lot), and the system performance was outstanding in temps up to 85 F - the warmest it's been here in Utah so far this year. I had to back off on the refer temp setting to keep it from getting too cold. And, the noise from the original fan is gone.
So, even if I missed removing the resistors, the system performance is still awesome. But, if I could improve it more by removing the resistors, I'd like to pursue that.
Thanks in advance
RDM16CCD is offline   Reply With Quote
Old 12-17-2006, 10:35 PM   #20
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Northwest Panhandle , The Sunshine State/WBCCI 6637
Fans
I thought I would bump this one up.This is a great thread and I know a lot of people would love to get rid of the noise in there new Airstreams.I am getting a fan for the exhaust above the stove and adding 2 more in the refridge compartment outside.Even though it has the roof vent It still seems that if I add the fans it would work better in the summer.
Blue Numbers and Signs
E-mail me for quotes.
Devoman is online now   Reply With Quote
Old 12-18-2006, 04:19 PM   #21
Turtle's Avatar
Arcata , California
Hey Devo, What fan are you replacing the stove exhaust with? Report back and let us know how quiet it is. Jamie
Old 12-18-2006, 07:57 PM   #22
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Me too! I'd like to know that as well.
Devo also in terms of the fridge, I think you and I have the same one and in the dead of summer...hot, humid, etc, my fridge worked great...real cold inside.
Based on the possible recall of these fridges you and I have, I'd be reluctant to modify the fridge in any way, if in fact our units are under the same recall for a possible fire hazard due to a leak developing in a weakened weld due to an oversized heater coil being used.
Old 12-18-2006, 10:27 PM   #23
Commercial Vendor
Devoman's Avatar
Recall
HMMM...I did not know anything about a recall.Where would I be able to source out things like this to find out what items need to be fixed?If mine does have to be recalled I am going to get them to pull that RCA wire and run thru the wall while they have it out.
The fan I am going to try and use are the ones from eastluna.It seems they have the lower dbi's so I will be trying those.As for the fridge.You know when you look into the outside compartment and see the wood box that is in front of it.I figured I would angle the fans towards the fridges workings to get the full effect on them and it would force the air out the top.I am also going to try and fit a piece of aluminum on there so it can be removable if it has to be worked on also.I dont want the fans to be attached or near the louvered hatch because I would like them to last as much as possible without getting water when washing it and rain when it is pouring.Once I get these items and try to do something I will post.
Old 01-14-2007, 06:36 PM   #24
Commercial Vendor
Profile:  Currently Looking...
east stroudsburg , Pennsylvania
The cooling kit I manufacture is quieter and superior than the factory fan, plus if you got the double side vent, you don't have to remove the refer to install. The whole kit is less than the 50 some dollars one fan mentioned in this thread costs. I'm not busting on anybody's modifications, but just letting people know there is a kit available if they want it.
RV_cool is offline   Reply With Quote
Old 01-14-2007, 07:18 PM   #25
Los Alamitos , California
Nice Price!
Thanks RV_cool,
I will definately look into this when I get our new AS 16' Bambi!
Thanks for the link,
Best regards,
Don
LifeguardTwr is offline   Reply With Quote
Old 03-28-2007, 05:31 PM   #26
DandB^2's Avatar
Profile:  2007 16' Bambi
Reno , Nevada
Many Thanks
This thread is great! I just completed the install of the dual fan system with the DPDT switch shown in the image above. It works great, very quite even in parallel mode and the cooling seems quick. One quick question, I setup the fans to blow air over the condenser not pull air from it. Is there any reason why it would be better to pull air over it instead of blowing it accross it? It seems much cooler now but just curious. Anyway, thanks to all for helping me get a noise free evening in the trailer.
Cheers,
Doug
DandB^2 is offline   Reply With Quote
Old 03-29-2007, 03:51 AM   #27
rseagle's Avatar
Images: 33
Remember that hot air rises. The air you a sucking in from the top vent is blowing down over the coils. The air is heating up and wants to go where the fans are. Seriously consider have the fans blow out of the upper frig vent.
2004 22' CCD
1997 F-150
WBCCI# 1430
AIR# 4749
Old 04-16-2007, 02:02 PM   #28
just jd.
5cats's Avatar
Profile:  2007 20' Safari SE
San Diego , California
alternative fan
I used a Scythe S-FLEX SFF21D (Scythe USA Inc.) replacement fan. At 8.7dBa and $15 a pop I think it's an excellent alternative.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 // xxxx
5cats is offline   Reply With Quote
noisy refrigerator fan Turtle 1999 - 2004 Bambi 9 06-03-2004 04:45 PM
Another Approach to Refrig Fan? wvmiller Refrigerators 2 04-10-2004 06:59 PM
Selling 1987 Airstream Model 345 Guy For Sale & Wanted 0 03-07-2004 09:21 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 11:44 PM
Recent Model Parts Books in PDF format thenewkid64 Link Archive 1 08-05-2002 02:29 PM
