05-27-2014, 07:58 PM
2013 16' Sport
Boulder
Refridgerator not working on gas
Hi, I need some diagnostic help if anyone has any to offer:
I have a Bambi, Dometic 2351 fridge. Runs fine on electicity, but not firing up on gas. I have:
recycled ignition sequence
replaced 1A inline fuse and 3A circuit board fuse
The gas canister full
The lines are clean (stove and water heater working)
No gas or flame coming into cylinder
Thoughts, oh wise ones?
Caroline
05-27-2014, 08:48 PM
2013 16' Sport
Boulder
Refrigerator not running on gas
(just correcting my typo!)
05-27-2014, 08:59 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Does it light or try to light? Does it make a spark?
05-27-2014, 09:02 PM
2000 31' Land Yacht
Central
Last time mine didn't work on gas, flame was not right, took it apart and cleaned orifice. Spiders love to hang out in small places.
05-27-2014, 09:06 PM
2013 16' Sport
Boulder
No spark or attempt to spark. Just a short, quiet click, sounds like coming from the circuit board.
05-27-2014, 09:14 PM
2013 16' Sport
Boulder
Waited for it to re-cycle ignition sequence. Could hear a very quiet thunk before check light came on (I'm right there looking in the bottom compartment, not in the trailer)
05-27-2014, 09:19 PM
1972 31' Sovereign
Benton
, Arkansas
Mine is a different brand, but the first thing it tries to do is spark, then gas comes on.
I am thinking it is either a loose connection or a failed circuit board.
Unfortunately, of the two, it is probably the later.
05-27-2014, 09:26 PM
1972 31' Sovereign
Benton
, Arkansas
It could be an ignition system failure too.
05-27-2014, 09:32 PM
2013 16' Sport
Boulder
Thanks for your help. Looks like I gotta take it in. Until then, it's just a nice cooler with shelves!
05-27-2014, 09:46 PM
1972 31' Sovereign
Benton
, Arkansas
Sorry it couldn't have been something simple.
06-25-2014, 09:58 AM
2006 19' Safari SE
Hayes
2351 Refrigerator
Seacue,
Bambi 2351 Refrigerator no gas operation
I see that we have the exact problem with the gas operation of our Fefrig, and I was just wondering if you ever fixed yours, and what you did. I have one more problem than you; I cannot move the gas shutoff valve. It is on but will not turn. I am being very careful when attempting (she froze tight--any suggestions on how to "unfreeze" ). I posted my problem but no one wanted to tackle it is the reason I am asking you. Many thanks. Tom
If this goes to the wrong place again, s o r r y(however, I am trying)...
06-25-2014, 10:06 AM
1972 31' Sovereign
Benton
, Arkansas
Which gas valve? The one on the unit itself or an in line valve?
06-25-2014, 10:10 AM
2013 16' Sport
Boulder
Tom, we have not yet fixed our fridge. We believe it is the ignition system, because when the fridge turns on we can smell gas -- just no spark. We are taking it in to the RV dealer next week: will report back!
I will defer to those more knowledgeable regarding your frozen valve!
caroline
06-26-2014, 01:44 PM
2006 19' Safari SE
Hayes
Afraid you would say that....I have pushed,pulled, tried turning, and nothing works. Oh well, don't need it this next trip anyway so will leave it until we return from the Keys. Many thanks, Tom
06-26-2014, 03:43 PM
2007 28' International CCD
Springfield
Easy to light manually if needed just open access door on the outside of the trailer remove the 2-3 screws from the inspection plate for the burner.Have someone in the trailer push the button for lp on the refrigerator to on.Once its on light with a lighter (you have about 45 seconds to light it).Once lit you are good for the duration.
The circuit boards are a weak link in the system.Buy a Dinosaur circuit board if a replacement is needed as it is a much better design and more durable.Approx cost $100.00 and 15-20 mins to install
06-27-2014, 09:48 AM
2006 19' Safari SE
Hayes
I will thank you from here having duplicated problem...I never thought of that...many thanks
07-30-2014, 12:04 PM
2013 16' Sport
Boulder
Hi All, thought I'd circle back around on the original post. It was the circuit board, fortunately under warranty. The dealer has had my trailer for over 3 weeks to repair, but that's a rant for another day.
caroline
07-31-2014, 04:25 PM
2006 19' Safari SE
Hayes
Thanks for the update...I may have same problem. Oh well, will leave it for another day. Many thanks.
