Old 06-26-2014, 03:43 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Easy to light manually if needed just open access door on the outside of the trailer remove the 2-3 screws from the inspection plate for the burner.Have someone in the trailer push the button for lp on the refrigerator to on.Once its on light with a lighter (you have about 45 seconds to light it).Once lit you are good for the duration.
The circuit boards are a weak link in the system.Buy a Dinosaur circuit board if a replacement is needed as it is a much better design and more durable.Approx cost $100.00 and 15-20 mins to install
Old 06-27-2014, 09:48 AM   #16
2006 19' Safari SE
Hayes , Virginia
I will thank you from here having duplicated problem...I never thought of that...many thanks
mocus is offline   Reply With Quote
Old 07-30-2014, 12:04 PM   #17
2013 16' Sport
Boulder , Colorado
Hi All, thought I'd circle back around on the original post. It was the circuit board, fortunately under warranty. The dealer has had my trailer for over 3 weeks to repair, but that's a rant for another day.
caroline
Seecue is offline   Reply With Quote
Old 07-31-2014, 04:25 PM   #18
2006 19' Safari SE
Hayes , Virginia
Thanks for the update...I may have same problem. Oh well, will leave it for another day. Many thanks.
Humphrey gas light not working properly bmklawt LP Gas, Piping, Tanks & Regulators 6 12-05-2011 09:58 AM
Dometic not working on 12V, ok Elec & Gas afordjones Refrigerators 1 08-16-2011 06:02 AM
My Gas Detector is not working, at all J5MM LP Gas, Piping, Tanks & Regulators 13 07-22-2011 07:04 PM
refridgerator on gas FireFighter Refrigerators 1 08-31-2004 10:55 AM
Refridgerator was working Just Fine,...til I started messing with it MileHigh Refrigerators 2 06-12-2004 12:56 PM
