Old 05-19-2004, 06:34 AM   #1
wbcci3371's Avatar
1993 34' Limited
Scituate , Massachusetts
Refer Won't Stay Running on LP
A side by side 10 cubic ft. refrigerator won't stay running on LP.
I have cleaned out the flame tube with a brush, cleaned the slots in same. All other LP appliances work fine.
This happens anytime whether or not there are other LP appliances running.
Any comments & help is appreciated.
Rich
wbcci@comcast.net
wbcci3371 is offline   Reply With Quote
Old 05-19-2004, 08:27 AM   #2
Rich.
Check the LPG pressure. It must be between 11 and 13 inches of water column pressure. 12 or 12 1/2 is preferred.
Also, the "oriface" must be cleaned. If it is partially plugged, then what ever else you do won't matter, because the reefer will not cool properly.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-19-2004, 06:39 PM   #3
Rich:
I have a 93 Excella and had the same problem you are having. It would not run on gas. I finally found out that there was a factory recall on the Dometic Fridge in the 93's. They had bad control boards. Problem is the recall was in the mid-90's and Dometic would not help me. It should have been corrected then, but the previous owner failed to take it in. In my case, the board and part of the wiring harness was changed and that cured it. I think the cost was about $75.00. Of course Inland Andy has worked on these things forever, so I would follow his advise before I hauled in a new board and wiring harness. Good Luck. Jeff
pjlingl is offline   Reply With Quote
Old 05-20-2004, 12:14 AM   #4
JanP's Avatar
Wink Refer wont run on LP
One thing you might check is the thermocouple. The thermo needs to be in the flame. If the thermo is in the flame, the flame starts and then goes out, the thermo maybe defective and needs to be replaced.
Ernie and Jan
JanP is offline   Reply With Quote
Running gear balance? Cedars Axles 79 06-10-2004 02:57 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
Refer heat / venting JaceBeck 1997 - 1999 Safari 3 08-21-2003 08:40 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
