There are a few common reasons.
Spider nest at the burner orifice. Stink bugs in the burner tube. Air in the gas line. Bad thermocouple.
In this order and attempt to light as you go. Crack the gas line at the gas valve till you smell gas. Remove the burner tube and check for stink bugs or spider nest. Lastly attempt to light while the burner shield is off so you can see the flame. If it lights for a second or 2 and goes out make sure the thermocouple is in the flame. If it is and still will not stay on replace the thermocouple.
2004 Excursion 4x4
