Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 07-15-2006, 08:13 AM   #1
kevino
Profile:  2005 25' Safari
Timberlake , North Carolina
Refer woes
Hi all,
Went to fire up the refer on propane this morning to pre chill it for our camping trip this week and couldn't get it running on propane. The check lamp comes on after about 30-45 seconds. I can smell propane when I poke my head in the refer access door on the side of the camper. I think it's geeting gas but no spark. It's a Dometic Americana Plus 2 way in a 2005 Safari SS. I hooked up to shore power and the refer is working fine on AC.
Any advice?
Kevin
kevino is offline   Reply With Quote
Old 07-15-2006, 08:22 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Remove the access panel at the bottom of the heater section and have someone else turn the refer to gas operation. See if the igniter is sparking. If not it could be dirty and if it is and still not igniting, you could have a clogged gas orifice. The LP buner section should be cleaned annually anyway.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-15-2006, 08:47 AM   #3
kevino
Thanks Lew. I'll check the ignitor. I'm pretty sure the orifice is OK because I can smell gas.
Old 07-15-2006, 08:56 AM   #4
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Similar happening
My former Classic 25 had a strange habit. If the trailer had been stored for more than a week, the fridge would not light and, like you, I could smell propane. I would remove the shielding, prop a lighted lighter in place, and go inside to push the button again. I had cut a little block of wood that would keep my stove lighter burning hands off.
Once lighted, we could go on a month-long trip and it would switch back to propane seamlessly each time we broke camp.
Store it for a week or so and it wouldn't light again!
The cooling unit finally died and the replacement worked OK every time. Apparntly, the electronics had to warm up for a time before it would spark.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 07-15-2006, 05:59 PM   #5
kevino
Update
Thanks again guys.
I went back over to the storage lot this evening. The refer was chilled down and the outer working were warmed up. I pulled the burner shroud off and told my wife to hit the "gas" button. It fired right up.
John- sounds like this refer might be a distant cousin of the refer in your former Classic.
New refer. 77caravaner Refrigerators 1 10-31-2002 11:04 AM
upload woes carmen Our Community 8 10-05-2002 04:21 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
