Yes that is the size it should be, but you can do your best to seal the fridge compartment area from pests by having your belly pan and floor screen in good condition and (I am assuming your refer is out now) so replace them if needed and when you put the fridge back in put foam tape around the areas where the fridge contacts the cabinetry and counter tops and also where the cabinetry meets the aluminium wall. Doing your best to get the air tight seal in that area help the chimney effect needed for the proper operation of the fridge.
And as a plus all of the foam tape sealing keeps your trailer from being drafty
