Old 02-18-2016, 05:09 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
refer tripping GFI
Got a Dometic Rm something vintage 1997, just replaced the circuit board.
Works great on Gas, but once I switch to AC GFI trips after about 2-3 minutes.
Where can I start looking?
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 02-18-2016, 05:40 PM   #2
Southwestern , Ohio
Unfortunately, you shouldn't be running the refrigerator on a GFI. The reason is that the insulation resistance of a heating element is not as good as the insulation resistance of ordinary room temperature insulation and there may be enough leakage to ground to trip the GFI.
If you can't move the refrigerator to a non-GFI protected circuit you might try replacing the heating element, in the hope that the new one will have less leakage.
Nuvite-F is offline   Reply With Quote
Old 02-18-2016, 08:21 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Peter is GFCI in the AS or home panel?
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-18-2016, 08:55 PM   #4
Airstream Driver
1997 30' Excella
Images: 51
Its factory in the Airstream panel. Got a new toy, Channing 1997 30'. How did they wire the fridge in your 1999?
Thanks Nuvite-F for the reply
1996 Airstream B190
AIR #13
Old 02-18-2016, 09:51 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'm betting thkat as the heating element warms up, a leakage to ground is created. I'd replace the element rather than move the fridge to a non-gfi circuit.
Old 02-19-2016, 05:29 AM   #6
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by drboyd View Post
I'm betting that as the heating element warms up, a leakage to ground is created. I'd replace the element rather than move the fridge to a non-gfi circuit.
Makes sense, since its an inexpensive replacement.
1996 Airstream B190
AIR #13
Old 02-19-2016, 06:52 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Peter.. agreed I would try replacing the GFCI as on mine.... Now, on my 1999 there were no GFCI.. inside or out. I made a mistake and "bonded" the neutral and ground... GFCI would pop within a few seconds...
One thing to note.. I have had GFCI go bad... then make sure there is no 'bonding of the wiring...
Since the AS is older, I would take an extension cord on a GFCI circuit and plug the FRIDGE ... if GFCI pops... then the problem is in the FRIDGE...
Channing
WBCCI# 30676
Old 02-19-2016, 09:44 AM   #8
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Is it a 15 amp or 20 amp gfi?
15amp are well known for false trips. More so as they get older.
20 amp not so much.
I either case, I would replace the gfi with a new one.
Probably solve your problem.
Ultradog is offline   Reply With Quote
Old 02-19-2016, 10:08 AM   #9
Hampton , Virginia
Looking at the title of the thread my first thought was, maybe you shouldn't be smoking that stuff in the airstream!
Getaways is offline   Reply With Quote
Old 02-19-2016, 04:59 PM   #10
Airstream Driver
1997 30' Excella
Images: 51
Yup, popped the GFCI with an extention cord in my shop as well. Time for a new heating element.
Thanks everyone for your input
1996 Airstream B190
AIR #13
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 01:15 PM
GFI tripping altamont Batteries, Univolts, Converters & Inverters 19 09-04-2008 11:22 AM
Dometic RM100 tripping GFI tschat Refrigerators 3 08-21-2006 09:01 PM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 06:17 PM
