Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-28-2003, 07:52 PM   #1
art
Profile:
refer shorting out
gas works fine ,tested element ,seems to work fine ,(no short) but keeps tripping breaker. Im thinking its the cord on the refer shorting out when it wants to ,Has anyone else run into this ?
art is offline   Reply With Quote
Old 04-29-2003, 09:09 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Art.
It can also be a defective heating element.
You can check it by removing it.
inlandrv.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 04-29-2003, 03:35 PM   #3
art
Profile:
Andy thank you very much for your reply. I took the element out and had it checked at the local rv shop .they put power to it and it heated fine.Brought it home plugged it in and the breaker tripped again hmmmmm.I think Im just going to make up a New cord.Ill have to wait for the weekend to try and find cinnectors .
Old 04-29-2003, 07:04 PM   #4
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Art,
The best way to track down your short is by disconnecting items, like the heater, the thermostat, the switchover device and isolating different components while plugging the cord back in. A simple process of elimination. Your element may be heating ok but could be shorting out thru the casing, did they check for that? I would reinstall it and plug the fridge in with it connected and disconnected, see what trips the breaker. Another thing, if you are running off a GFI they can be ultra sensitive, might take less than a direct short to ground to trip the breaker.
Chas
Chas is offline   Reply With Quote
Old 04-30-2003, 04:51 AM   #5
74Argosy24MH
Profile:  LOST , Hawaii
Check the cord and box it is plugged into first. Screws loosen and cause shorts, especially in plugs.
John
74Argosy24MH is offline   Reply With Quote
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 03:24 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 08:40 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
