Old 10-09-2016, 06:59 PM   #1
extiger's Avatar
2011 30' Classic
Kingwood , Texas
Refer Replacement
My Dometic refer was not keeping food cool enough during some summer trips. While in Bob Jones RV in Houston for some other work I asked them to see if there was something that could be done to improve the Dometic functionality. They diagnosed it as the cooling unit was failing. After considering the various alternatives I elected to replace the Dometic with A Vitrifrigo Sea Classic DP2600, an all electric refer designed for use in boats. It works on both 120v ac and 12v dc. AER Marine Supply in Seabrook had one in stock and Bob Jones did a great job with the install.
After one trip we are very happy with the Vitrifigo. It cooled and functioned as expected. It is a smaller unit than the Dometic in size but the same cubic foot interior. The layout is a little different, particularly in the freezer where there is no shelves on the inside of the door. Also the refer interior light is LED so hopefully it will not have the continual issues I experienced with the interior light and switch on the Dometic. I think the 12v going down the road will be more reliable than the Dometic.
Chris and Harry at Bob Jones were super easy to work with and did a first class job on the removal of the old unit and installation of the new. I highly recommend them for work on an AS.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Atwood Helium refer replacement for RM1303 PeterH-350LE Refrigerators 6 06-05-2015 01:06 AM
345 Refer is Tango Uniform, replacement advice? Honkity Hank Classic Motorhomes 18 09-12-2011 10:31 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
