Old 01-18-2011, 10:52 AM   #1
1972 29' Ambassador
Scobey , Montana
Refer flue cleaning
1972 29 ft. Dometic Refer. I have done everything and isolated my gas cooling problem to a plugged flue or a missing baffel. Instead of removing the fridge, has anyone tried removing the AS vent cap from the top of the trailer and going down for a solution.
walterw is offline   Reply With Quote
Old 07-15-2015, 05:33 PM   #2
1970 29' Ambassador
Port Rexton , Newfoundland
i have the same thoughts..
I know this is an old post but did you ever get an answer? I really don't wanna pull the vent cap off..
NfldAir is offline   Reply With Quote
Old 07-15-2015, 06:44 PM   #3
1994 30' Excella
Mississauga , Ontario
It is less than an hours work to undo gas line etc and pull the fridge into the kitchen. that's what I'd do if I was you. I did it to replace the cooling coils on the back. Not that bad a job. Then you can remove the chimney from the fridge and do a really good job.
Al
Al and Jean
TAC ON-3
