Old 11-11-2006, 01:55 PM   #1
Refer electrical question
When I bought my 91, the Dometic refer igniter (white plastic model 679) was fried. Advice was to replace it and verify that 12V is present on one of the terminals. Problem: I don't get 12V directly off any of the 679 terminals but there is 12V coming into the terminal block red wire. Is that the 12V I'm looking for or should I get 12v out of one of the 679 terminals? And, if not, what to check next? Thanks
ldetsf is offline   Reply With Quote
Old 11-11-2006, 02:14 PM   #2
Tinsel Loaf's Avatar
If the red block wire is 12 volt DC it shouild work as long as the 12 volt wire is the correct size for the refer like #4.
Tinsel Loaf is offline   Reply With Quote
Old 11-11-2006, 03:17 PM   #3
OK, so I replaced the igniter (reigniter) and purged the gas line (turned on stove) and tried to start the refer on LP several times. Won't start. Any suggestions? Thanks
Old 11-11-2006, 04:11 PM   #4
Sorry, found a wire came loose. All is well now.
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
