Old 11-21-2002, 08:13 PM   #1
Images: 55
refer door seals
Hi. Does anyone know of a online supplier of replacement refrigerator door seals for a dometic refer in a 73 sovereign?
Thanks in advance.
Tripp
Tripp is offline   Reply With Quote
Old 11-22-2002, 06:25 AM   #2
LOST , Hawaii
Try this link or a local appliance parts dealer may have something that would work.
John
74Argosy24MH is offline   Reply With Quote
Old 11-22-2002, 09:39 AM   #3
Images: 55
Thanks for the links.
I'll check them out!
Tripp
Old 11-27-2002, 05:07 PM   #4
Guitars's Avatar
John, The fridge in my '67 Safari is an Electrolux. Do you or anyone else have a source for a door seal? I didn't see one in the links you gave. Bill....
Guitars is offline   Reply With Quote
Old 11-27-2002, 06:07 PM   #5
LOST , Hawaii
You can try this, they can probably send you to a local distributor.
Electrolux Home Products North America
250 Bobby Jones Expressway
Martinez, GA 30907
706 651-1751
Electrolux owns Frigidaire and Dometic. It might be one that is made under multiple brands. If it is an absorption refrigerator check your door size against the Dometics, you may find one that is the same model, different name.
If it is a genuine European import, try this.
John
Old 11-27-2002, 06:44 PM   #6
Guitars's Avatar
John, You are Good! Thanks, for being such a great help, Bill....
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 03:24 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 08:40 PM
refer shorting out art Refrigerators 4 04-30-2003 04:51 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
