Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-01-2007, 08:27 AM   #1
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Refer - AC/good - LP/bad
We have an '05 Safari 25FB with the Dometic double door refrigerator, Model RM2662RB. It works great on AC, but is not doing real well on LP. All indications are that the LP systems are working properly. We have used the trailer extensively, and the LP operation has never been as good as the AC operation, but acceptable. On our current trip, it has been very hot (95 during the day) and the LP operation has been awful.
Is this the norm, or do I need to do something?
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 09-01-2007, 10:42 AM   #2
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Refrigerator Problems
Similar problem, but worse than yours yesterday:
Dometic Refrigerator
Mine have always worked better on LP, till the burner clogged.
Best of luck,
Vaughan
Old 09-01-2007, 10:54 AM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
moosetags,
If your fridge is operating normally on 120VAC, then there is a problem somewhere in the LP delivery system. Step 1 is to remove and clean the gas orifice and mixing tube where the air and LP mix. You coul have spider webs there. You should also remove the spiral baffle from the chimney (this may require removal of the unit from it's current position) and thoroughly clean the baffle with a wire busk and steel wool or ScotchBrite pad.
The next step is to check the LP pressure at the gas valve of the fridge. When all else fails, the gas valve may be set too low and is not providing the proper amount of BTU's to the burner. This condition will not allow the refrigerant solution to get sufficiently hot and will negatively affect the performance.
If you are not comfortable with using a manometer and adjusting a regulator, I would suggest you have this done by a licensed LP repair facility. Propane is nothig to fool around with .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 09-01-2007, 10:57 AM   #4
nickcrowhurst
Profile:
I've detailed the flue overhaul procedure here:
http://www.airforums.com/forums/84628-post1.html
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-01-2007, 08:57 PM   #5
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I have had an almost identical problem with a recently installed Dometic 2625. Worked fairly well on 120 v, but not so good on LP. I took a cover off where the gas shutoff solenoid is, and found a small thumbwheel there, with a line inscribed on it, and the word "off" stamped on it. The "off" part was almost in line with the line inscribed. I turned the thumbwheel away from the line, and the gas now sounds different, a tiny roar instead of almost nothing. I'll know in the morning if this fixed it, and will let y'all know then.
overlander63 is online now   Reply With Quote
Old 09-02-2007, 07:11 AM   #6
overlander63
Rivet Masher
L.A. , California
Okay, after twisting the knob, the temp went from 65 to 42 overnight, coldest it's been when running on LP. Looks like that fixed it, and with any luck, y'all's will be as easy.
Refer Blues Lumatic Refrigerators 8 05-14-2007 06:14 AM
Anyone out there with refer as old as mine? 1959newbie Refrigerators 37 09-12-2006 09:37 PM
Refer woes kevino Refrigerators 4 07-15-2006 06:59 PM
Refer Madness! TroutStream Refrigerators 11 08-08-2004 12:36 AM
New refer. 77caravaner Refrigerators 1 10-31-2002 12:04 PM
