Old 07-25-2007, 11:17 AM   #1
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
ref. scoop
so call me cheap, call me frugal, but the previous owner in his quest to gut our trailer busted out the scoop for the fridge vent. We're ordering a new fridge, but need a scoop. I see them new for tons of money, and have found used ones that are still around or over a 100 bucks. Is there any reason a scoop can't be built out of a hardboard, sheet metal, or lexan or some other type of flexable material that can be sealed air tight? I'm having a hard time justifying something that expensive that won't be seen if I can build something that suites the same purpose for a fraction of the cost.
goransons is offline   Reply With Quote
Old 07-25-2007, 11:25 AM   #2
Images: 59
Sure. Also, you can make it slimmer if you build it into the wall. Needs to be about 100 sq inches cross section.
ID:	41937   Click image for larger version
ID:	41939   Click image for larger version
markdoane is online now   Reply With Quote
Old 07-25-2007, 11:42 AM   #3
goransons's Avatar
1963 22' Safari
wall
so did the original scoop use the outside wall as part of the chimney or was it a full tube. I was under the assuption that it was a c shaped channel, but never having seen more than pictures I wasn't sure.
Old 07-25-2007, 11:58 AM   #4
Images: 59
I believe the original mounted on the inside wall, and was a channel as you describe. It was about 5" deep and 22 inches wide, I think.
My trailer didn't have one, so I needed to build one from scratch.
Old 07-25-2007, 01:19 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Thumbs up Very Nice Work!
Thanks for the photos. Very clean.
Vaughan
Refrigerator ducting Forrest Refrigerators 15 11-08-2013 10:15 PM
True story:NEIL ARMSTRONG 53flyingcloud Off Topic Forum 7 11-28-2002 05:50 AM
Ref pilot Dbraw Refrigerators 2 08-27-2002 05:43 PM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 07:19 PM
Taking apart Credenza.... niftypkg Cabinets, Counter Tops & Furnishings 4 07-22-2002 03:32 AM
