Old 05-07-2015, 04:59 PM   #29
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This is what the condensate drain on a Sport 22 looks like. The water drains into a cup, which rests on the hot coolant tube, and is evaporated by the heat of the tube:
Old 05-07-2015, 07:38 PM   #30
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Okay, that's similar to mine. Where is the electrical connection the OP was concerned about?
(I see in my prior post I was obviously still thinking about the air conditioner drain... Oops.)
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-07-2015, 10:57 PM   #31
Boxite's Avatar
2008 22' Sport
I have a 22' Sport and it does not have that evaporator cup. Mine is a 2008. What year trailer and brand refer is the one depicted?
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 05-08-2015, 01:16 AM   #32
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by mandolindave View Post
There ain't nothin wrong with being safe, especially if it gives you piece of mind. The fact is…most of us have or will make modifications on our Airstreams. I took your heading as tongue and cheek, and there is nothing wrong with a sense of humor either.
I am thinking that most of the folks that are complaining don't have a drain right above an electrical connection. For what it's worth, I don't think I would have designed the drain the way yours was.
I have an alert for you. One time I was at a campground where the polarity was reversed on the electrical outlet. My daughter was barefoot, and when she went to open the door, she got a shock. My trailer has a warning light for when this happens, but it is street side, so I didn't notice it. I can't think of a way to ground the electrical so you won't get a shock when the polarity is reversed, but maybe a buzzer would be better than a light that you can't even see in daylight. Yeah I always check the power hook ups and especially extension cords now.
Hi, this is one reason that I keep a polarity tester plugged into one of my kitchen outlets and check it every time that I plug into shore power, even at home. I also made a polarity tester for testing the power post before plugging my shore cable into it. I also use a Kill-A-Watt.
ID:	237995   Click image for larger version
ID:	237997   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Furnace Recall (model number location) idahoan Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-17-2011 07:10 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
"Stupid is as stupid does"... Tin Diesel On The Road... 7 08-14-2009 08:59 PM
dometic refer recall update wasafari Refrigerators 40 06-17-2007 06:36 PM
