Old 08-20-2013, 03:09 PM   #15
Ottawa , ON
Originally Posted by mrdotson View Post
I have a 1978 Excella 500 with at Dometic and have broken the gas/electric selector, any ideas where to find the model number for the fridge or the selector?
John
John,
Look in through the hatch on the outside of your trailer behind the refer: there is a paper diagram there on the back of the refer where the model number was marked on ours.
But even if you aren't able to find the model number, I think if you just asked for the selector knob for that year, you should be OK.
I would start with Dometic directly...
Contact Information
For RV products
Customer Support Center
2320 Industrial Parkway
Elkhart, IN 46516
Phone: 1-800-544-4881
CustomerSupportCenter@DometicUSA.com
Old 08-28-2013, 05:34 PM   #16
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
I am refurbishing a 77 28' Argosy. It has the original Dometic RM 100 model fridge. I promised the wife to buy a new one. Dometic suggests models RM 2820,2852,2862 or 3962. The 2820 seems to be the only slide in fit. All others will require raising pantry for the unit. I have only found one review of the 2820 that was on Amazon and it was not very positive. Anyone have expereice with a new model?
Reading several other forums, some people put in a residential fridge and use their battery while boon docking. What experience does anyone have? I already plan on upgrading to a new converter and may even try to place two 6 volt batteries instead of a single 12V. They would have to go under the bed but I think I heard on VAT that AGM batteries do not need to be vented. Am I correct?
Too many choices, too many options, too little knowledge. LOL
buffaloman is offline   Reply With Quote
Old 08-28-2013, 11:08 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You will need an inverter, a big one! and a large amount of battery capacity or a generator to boondock with a residential fridge.
Old 08-29-2013, 06:10 AM   #18
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Another option is the refer with a Danfoss type compressor.
Lance
Top is offline   Reply With Quote
Old 08-30-2013, 01:00 PM   #19
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
It is good that you are going to two golf cart batteries. I boondock a lot and I can easily go 4 or 5 days without charging my batteries. Normal battery load is lights (I have LED), water pump, some use of the fan and possibly some tv. My fridge runs on propane. If you use a residential fridge, you will run your batteries down in a matter of HOURS. Camping is no fun with dead batteries. Don't use a residential fridge.
When you upgrade your converter, you may want to install a "battery tender" to keep tabs on your battery voltage. I got both from Industrial Device Networking - Serial, Ethernet & USB - B&B Electronics.
Dan
Old 08-30-2013, 01:08 PM   #20
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I mad a mistake on the link for best converter. It is: BestConverter - Converters, Inverters, Electrical Supplies, Electronics
Dan
Old 08-31-2013, 11:24 AM   #21
mrdotson's Avatar
1978 31' Excella 500
Hillsboro , Tennessee
You may also want to repair the fridge while you are determining your options.
Dometic was very helpful as were the folks on this forum.
I found the parts manual and troubleshooting guide.
Below is a website for parts.
RV Parts Superstore
Perhaps this will get you fixed up in the meantime.
Best,
John
mrdotson is offline   Reply With Quote
Old 08-31-2013, 12:47 PM   #22
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm renovating a '76 Argosy28 rear-bedroom. The previous owner had replaced the 2-way fridge with a stacked pair of junky dorm fridges, and never camped without hookups or traveled far, so it worked for them.
I'm planning to put in a Dometic Tundra with the Danfoss 12v compressor. Long-long term, I may add solar to the roof, but in the short term I'm just going with 2 batteries and relying on the generator I already have when boondocking. It costs about the same as a 2-way absorption fridge (the ones you were looking at) but works better in hot weather and isn't as finicky. Also, it doesn't require venting, though if unvented will add some heat to your interior like any fridge would.
— David
Old 09-01-2013, 08:34 AM   #23
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Well, the wife went to Camping World on Friday and she shopped for refrigerators. She looked at a RM2820 and then a RM3762. While the latter is smaller, she said the storage was better. She couldn't wait for me to fix the RM100 so we are now the new owners of the RM3762. I'll be installing it soon. I still plan on two batteries for boondocking. I wish I had known about the Defos compressor before she left.
