Old 02-15-2013, 08:44 PM   #1
1972 31' Sovereign
Espanola , New Mexico
R&R heating element
To whom it may concern,
What has to be done to replace heating element on Dometic rifrigarator? Can it be done without removeing rifrigerator/
jclemwk is offline   Reply With Quote
Old 02-15-2013, 09:49 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Chances are you will have to remove the refer. The access cover from outside is not large enough to get to the well (tube) that the element is located.
Old 02-15-2013, 10:39 PM   #3
1974 Argosy 20
Kooskia , Idaho
But you may not have to remove the refrigerator. I have had success in doing it from the exterior access port, but that very much depends on the specific AS you have.
Look at the boiler tube (the vertical metal tube on the right side (from the rear) of the refrigerator. You will see a set of wires (maybe in a flexible tube) going up to that boiler tube. Uncover what you can and there should be a stainless steel pipe about 3/8 inch diameter, with wires coming out of the end. That is the heating element. It has a 90 degree bend in it. Work it up vertically from the well that it fits in. Once you get it out, put the new one in where you removed the old one. Done.
Now, that sounds simple, but often they are rusted in place, or have burned out in such a way that they have welded themselves in place. It is those which are really nasty to remove in a confined space behind the unit. That is where TG T is correct, very hard to do without removing the refrigerator.
Best of luck, may be easy, may not.
Old 02-20-2013, 06:30 AM   #4
2000 31' Land Yacht
Fort Erie , Ontario
idroba is correct. I have removed the calrod after applying some vibration (exercercise great care here), twisting and (gasp!!!) some penetrating fluid ( which needs to be cleaned up after), suck out the rust scale. Before inserting new calrod use some zinc oxide ( used in electronic heatsink applications) to provide thermal conductivity and prevent future rusting in problems.
So workspace is very tight and expect some bruised knuckles. Otherwise reefer comes out.
Good luck
Steve
is.chowa is offline   Reply With Quote
Airstream Sport Versus Evergreen Element ZZSPIRAL Our Community 16 01-04-2013 09:56 AM
Aux Heat Element Question Ridgerunner3 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-12-2012 07:16 PM
2012 24SK Element Earthbound Evergreen RV Lightweight Like Airstream FALL SALE!! eBay Watch Airstreams on eBay 0 09-24-2011 06:00 PM
Heating system ideas? Tinpickle Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-31-2011 02:28 PM
UK heating question 3 Dog Nite Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-02-2011 10:05 PM
