Old 07-03-2019, 05:53 PM   #1
2018 23' International
Minneapolis , Minnesota
Quick fridge question
We picked up our trailer (18 Int’l 23cb) from the dealer (who was doing a little warranty work). We plugged in when we got to our campsite and then opened the fridge to find that it hadn’t been functioning in some time. I also noticed that the dealer set the battery disconnect to “store.”
So my question is whether the refrigerator (which had been set to auto) needs at least minimal battery power to run off of LP or if it’s some other problem.
Thanks for any advice.
Gopher John is offline   Reply With Quote
Old 07-03-2019, 05:57 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yep, control board requires 12vdc
Larry
lsbrodsky is offline   Reply With Quote
Old 07-03-2019, 06:01 PM   #3
Sag Harbor , New York
^^^^^x2
[Edit -- based on your Post #4 you have AGM batteries? If so ignore most comments below, but still test battery voltage. Solar charging may be limited, depending on what the dealer did]
Also . . . the batteries need to be fully charged and in good shape. If the dealer let them run down, they may be shot. Suggest unplugging from shore power and checking the water level in each battery cell. [using safety procedures described in your owner's manual -- gloves, safety goggles etc..] Use distilled water only to top off. After one hour without shore power, what does your monitor panel say the battery voltage is?
FYI, in addition to your owner's manual, this is a good source for basic info on RV battery practices:
http://www.batteriesnorthwest.com/batteryschool.cfm
If the batteries have been allowed to go under ~12.2 volts, their life expectancy has probably been affected IMO.
If your AS is still under warranty, the batteries are too probably. If problems persist, you might want to have the batteries checked by a dealer who carries your brand
You might also want to contact the dealer who left your Use/Store switch on Store. Why and for how long?
Presumably you have an adequate supply of propane?
Good luck,
Peter
Old 07-03-2019, 06:08 PM   #4
Peter,
I’ve got solar so battery depletion shouldn’t be an issue.
Thanks so much for the feedback :-)
Old 07-04-2019, 09:22 AM   #5
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Gopher John,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Quick question fridge Sbb Refrigerators 1 08-24-2016 12:59 AM
Quick fridge question! jgoss Electrical - Systems, Generators, Batteries & Solar 14 09-22-2014 07:25 AM
need quick help on Dometic fridge Tin Diesel Refrigerators 16 04-20-2009 02:45 PM
Quick 12v Question Dave-O Electrical - Systems, Generators, Batteries & Solar 8 03-05-2003 03:37 PM
quick question is it a 77 or a 76 overlander Our Community 23 10-03-2002 07:21 PM
