Old 08-03-2016, 01:25 PM   #1
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Quick, Easy & Safe refrigerator defrosting!
Using a hair dryer may be a quick way to defrost a RV refrigerator, but it may also cause damage. "Permanent damage could result from warping the metal or plastic parts,” says the Dometic User Manual.
We use our RV refrigerator full time (it acts as a supplemental refrigerator when at home) and it always has food in it, so it is important to be able to do the defrosting quickly, to prevent food spoilage and to shorten the recovery time for the refrigerator to get adequately cold again (40 or less)!
Reducing the buildup of frost and ice on the cooling fins helps to increase the refrigerator's cooling efficiency.
When our refrigerator needs defrosting (about every 2 months), I choose a warm day and gather 5 tools: a cooler, portable fan, Tupperware lid, chopstick, and a washcloth.
The fan rests on a nearby counter and blows warm air into the refrigerator and freezer compartments. The ice chunks begin to melt and can be gently nudged by the chopstick and slid off of the fins into the inverted Tupperware lid and deposited by nearby plants. The washcloth then cleans and wipes dry the refrigerator. The whole process is completed in less than 30 minutes!
See the full story, along with how the position of the thermistor probe regulates the refrigerator's coldness:
Quick, easy and safe RV refrigerator defrosting
Name:	DSC_0004 Overdue for defrost.jpg
ID:	268237   Click image for larger version
Name:	DSC_0002 Defrosting with fan.jpg
Name:	DSC_0016 Defrosting with fan.jpg
ID:	268240   Click image for larger version
Name:	DSC_0023 Ice chunks slide out.jpg
SilverGate is offline   Reply With Quote
Old 08-03-2016, 01:39 PM   #2
Long Island , New York
Great advice, thanks!
FWIW -- when it is time to get the fridge and freezer cold again, having large blocks of pre-frozen blue ice from the house can really reduce the wait time. If you have room in the house's freezer for multiple large blue ice blocks, the AS fridge and freezer can be back online in 15-30 minutes, meaning the entire operation can take as little as one hour.
Old 08-06-2016, 01:17 PM   #3
SilverGate's Avatar
2007 23' Safari SE
Great tip, OTRA15, thanks!
Additional tips on defrosting and keeping your refrigerator happy and working well are welcome here!
Old 08-06-2016, 02:03 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
That much frost on the fins I would check the door gasket. Take a dollar bill and close it in the door at various places and pull it out. The pull force should be the same all the wat around the door.
Now if the kids are in that frig every 10 mins all bets are off.
2004 Excursion 4x4
Old 08-06-2016, 07:04 PM   #5
SilverGate's Avatar
2007 23' Safari SE
Originally Posted by HowieE View Post
That much frost on the fins I would check the door gasket. Take a dollar bill and close it in the door at various places and pull it out. The pull force should be the same all the way around the door.
Yes, HowieE, those fins are overdue for defrosting, as mentioned in my History Safari Express post, "Quick, easy and safe RV refrigerator defrosting." I last defrosted the fridg last spring prior to our May trip. I just let the refrigerator go a little longer this humid summer without defrosting.
Thanks for the good tip about checking the integrity of the door gasket.
Upon completing the defrosting, I wipe down the refrigerator, including the gasket seals and spray the seals with a food-safe silicone spray: Molykote 316 (which I also use to lubricate the fresh water tank's sticky petcock drain valve).
Old 08-06-2016, 07:57 PM   #6
SilverGate's Avatar
2007 23' Safari SE
Airstream video, Hosted by: TrailerChix's Toril Milbrath:
How to Operate Your Refrigerator
Old 08-06-2016, 08:02 PM   #7
1976 Argosy 26
Fair Oaks , California
This little gadget helps also but just the fins directly in front of it .
http://www.ebay.com/itm/370591777926...%3AMEBIDX%3AIT
Argosy Heir is offline   Reply With Quote
Old 08-06-2016, 10:53 PM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I just install one of those fans from RV cooling warehouse. Keeps my fridge cooler on hot days. Tested outside my house in full sun at 96F and high humidity and the fridge ran under 40f. With fridge packe with food it performs better. Good upgrade for $20. I ran the wire through the the same hole as the thermistor wir and picked up 12v from the fridge 12v feed on the outside vent area. Fan has n on/off switch when not needed.
Kelvin
Old 08-07-2016, 12:49 PM   #9
SilverGate's Avatar
2007 23' Safari SE
The location and position of the thermistor can affect the refrigerator's coldness:
Adjusting the Thermistor to Improve Cooling
Old 08-07-2016, 01:14 PM   #10
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I've got an Igloo apartment-style fridge that needs defrosting on a fairly regular basis. It has a drain hole in the fridge area, which I plumbed to go outside, so that's fine. I bought a New Star 36893 Commercial Grade 18-Gauge Aluminum 2/3 Size Sheet Pan, 15 by 21-Inch from Amazon that just fits in the freezer. If I monitor the pan, I can keep dumping it before it overflows.
As for the actual defrosting, living in S. Florida and turning off the A/C works just fine for a fast defrost!
SuzyHomemakr is offline   Reply With Quote
Dometic DM 2852-defrosting? badkat General Appliance Topics 6 11-21-2014 05:21 PM
Heading West to Florida need an easy quick route Mikec1231 On The Road... 18 10-06-2014 04:38 PM
Defrosting Fridge Mark910234 General Repair Forum 12 07-24-2013 03:08 AM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 12:14 PM
