Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-30-2011, 08:05 AM   #1
Lothlorian's Avatar
Loganville , Georgia
question on refrigerator.
I hooked up the fridge to dc and ac. How long to know if it the coils are getting warm? I have had it plugged in for 20 minutes and I do not feel anything in the back getting warm.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-30-2011, 08:12 AM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Russellville , earth
I wouldn't expect much for a couple hours or so on AC or propane. For DC I wouldn't have a clue beyond the sense that it would take a very long time as my understanding it is meant to help maintain the temp once cooling has occurred. Anyway you go, expect it to take some time.
Rodney
Visit my photography and painting website
https://rooseveltfineart.com
Instagram is r.w.roosevelt
Boondocker is offline   Reply With Quote
Old 04-30-2011, 08:21 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is this a two way or a three way fridge? If it is the original 2 way then there is no DC connection, but newer units do require DC for the circuit board. I would expect to feel some heat in on the coils in a short period of time. To get cold in the box will take much longer
Richard
azflycaster is online now   Reply With Quote
Old 04-30-2011, 08:22 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Ditto. I always turn the fridge on the evening before I need it. It takes hours and hours to cool. It seems you're checking out electrical operation, so it's probably irrelevant if I add that mine cools faster on propane.
5 meter Langford Nahanni
Old 04-30-2011, 08:35 AM   #5
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I always turn it on the night before and then pack only cold (cold pop etct) items in it. It takes a very long time to cool off but the freezer should feel a bit cooler fairly fast. We use a indoor/outdoor wireless temperature sensor to monitor it.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 04-30-2011, 08:49 AM   #6
Lothlorian's Avatar
This is a relatively new fridge. I got it used. I am smelling ammonia and the coils are not rusted.
Brian
Brian & Adrienne
Old 04-30-2011, 09:04 AM   #7
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Brian
I hope you meant that you are NOT smelling ammonia!
If you are smelling ammonia, you have a serious problem. The ammonia leak is almost always in the area of the AC heater. You would not see the area of the leak unless you remove the "stovepipe" and insulation around the area of the heating element.
Propane does cool the box slightly faster than AC because it puts more BTUs into the system. In both modes, you should feel heat in the tubing above the boiler in a short time.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Refrigerator control cratered Pahaska General Appliance Topics 6 04-22-2011 06:59 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
3 refrigerator installation questions Lothlorian Refrigerators 16 03-06-2011 09:40 AM
