Old 04-15-2011, 03:45 PM   #29
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Originally Posted by noreen View Post
Maybe Im cheap but I just freeze several 2 litre bottles and put them in the freezer and refrigerator. Has worked for 12 hour trips in 90 degree weather. Sal.
A good idea. In our case we have a small fridge with a weeks worth of food and don't have the room. Maybe we could try a frozen roast and schedule it for dinner when it thaws
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-15-2011, 05:00 PM   #30
Airstreamer
J5MM's Avatar
2012 27' FB International
Bellevue , Washington
Images: 78
We tow with the gas off. We are just paranoid I suppose but also we have found that once we put all of our food in the fridge and leave it turned on overnight -- the fridge turns into a cooler of sorts when we are towing and keeps the food relatively cool.
{blog}Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
J5MM is offline   Reply With Quote
Old 04-17-2011, 06:34 PM   #31
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
We just got back from our first weekend out in our AS. We towed with the refrigerator running on propane and had no problems what so ever. Since this was a short distance trip we didn't need to refuel. I presume that when we do need to refuel on a longer trip we just turn off the propane, fill up, pull away from the gas pumps, then turn the propane back on and the pilot light on the refrigerator will just relight. Thanks for all of the great advice and comments.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 04-17-2011, 07:20 PM   #32
What's a rivet?
SilverBreeze's Avatar
2008 23' International CCD
Napa , California
Never been a problem in almost 15,000 miles towing.
SilverBreeze is offline   Reply With Quote
Old 04-17-2011, 11:04 PM   #33
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
As can be seen in the chart in the link below, in Canada, only the Province of Newfoundland does not allow travel with the propane on.
All propane must be turned off before refueling, or entering a closed structure. ie ferry, shop, etc.
http://www.rvhotlinecanada.com/RV-Re...c=rv-resources
Dave
Old 04-18-2011, 04:22 AM   #34
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
My fridge stays on. A multitude of food born illnesses can result from storing perishable food at improper temperature (above 40 degrees) ... especially when temperatures exceed 40 degrees for more than one to two hours.
UAPachyderm is offline   Reply With Quote
Old 04-18-2011, 07:31 AM   #35
HCR
HCR's Avatar
Livingston , Full time traveler
Perhaps I missed a post here that expressed concern about having an open LP gas container should a mishap (i.e., wreck) occur while towing.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 04-18-2011, 07:49 AM   #36
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Certainly that is a concern,, But so is having a tank of gasoline on your vehicle. There are certain risks in life and one just has to decide which are acceptable
13 Ram 2500 TD
Old 04-18-2011, 08:25 AM   #37
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Lynn might weigh in on this to confirm or dis-confirm, but I think I read the newer valves have check valves that shut down flow in the event of a line rupture.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 04-18-2011, 09:56 AM   #38
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
The biggest concern is an accident which would result in a fire igniting the propane sources: i.e. the AS propene tanks. A propane fire burns at an impressive >2000 degrees F or so....a friend of mine is a firefighter and he lost his entire home to a barbecue fire from a malfunctioning tank.....not pretty.
The other danger is igniting gasoline fumes at a filling station if you have your refer on LP; even if you fill with diesel, the propane fed ignition in the refer might ignite nearby fumes from another pump. The risk is low, but it can happen. See the previous posts (page #1 ) regarding gas station fires.
We simply keep the propane on while traveling.....it is a risk but minimal...however we stop before entering a gas station, enter the unit, tap the "off" button on the refer, refuel, and on exit from the station, reenter the AS, tap the "on" button, and off we go......perhaps a little hassle, but not really significant, since we can grab a snack and check on the interior of the AS.
With age, I have become less "bullet proof", and less "invincible" compared to my younger days!
Zigidachs is offline   Reply With Quote
Old 04-18-2011, 10:21 AM   #39
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
In the 28 years I've towed Airstreams I've always towed "on" with no problem. My Limited has the automatic "off" feature and my TV is a diesel so that may add a degree of safety. Can't fault those who err on the side of caution though.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 04-21-2011, 12:40 PM   #40
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Smile Referigerator while driving
Let me try to explain in layman terms.
Any explosion or fire only happen to the air/fuel mixture when the ignition source is available. However, air fuel mixture can only burn within the LEL (low explosion limit) and HEL (high explosion limit). What that mean if the mixture is too rich with fuel or too lean with air it will not ignite. The probability of having the correct air fuel ratio next to the refrigerator flame is exptremely low.
After said that, it is upto the folks to decide. I never turn off my refrigerator, even when refueling the TV.
Zia is offline   Reply With Quote
Old 03-07-2012, 08:26 AM   #41
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
rented SOBs in the past
Ok, I know this is a dummy question but other than the common vernacular known to most, what does SOB stand for?
Old 03-07-2012, 08:30 AM   #42
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
SOB = Some Other Brand
Richard
Towing Questions Grotegut Tow Vehicles 65 04-26-2011 06:42 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Hand towing question imbeanie Towing, Tow Vehicles & Hitches 3 02-21-2011 05:09 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
