Old 05-05-2011, 09:41 PM   #1
dekew's Avatar
2010 27' FB International
Culver City , California
Propane light doesn't go off
Hi all,
I have a Dometic RM3762 that works well - except the little propane light stays on when it shouldn't.
It's a 2way fridge, and we keep it in "auto" mode - which means it should run on AC when we have shore power. At our last RV park, the light went off 20-30 mins after initially turning the fridge on, but now, the little LP light never goes off.
I think we've checked all the obvious things - enough power (30 amp), no loose wires, searched airforums for similar problems. Does anyone have anything else I could try to troubleshoot this? Again, the fridge works well, it just doesn't switch to AC as far as i can tell.
Deke, Tiffani, and Lucy the Cattledog
2010 27FB International CCD - "Big Weas"
2012 Ford F-250 6.2L V8 Crew Cab
Follow us on Weaselmouth.com, Connect with us on facebook and twitter!
dekew is offline   Reply With Quote
Old 05-06-2011, 05:32 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
One of these came into the shop doing what yours is doing, and I replaced the circuit board to get it working again.
Old 05-06-2011, 06:07 AM   #3
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
We don't have our trailer at home right now to verify this but we had the same problem. I found if I turned the fridge off, then back on, it would reset to run off electricity rather than propane.
SilverCottage is offline   Reply With Quote
Old 05-06-2011, 09:27 AM   #4
Goal15's Avatar
Dallas , Texas
Interested to find out the solution
Deke
will be interested to see what the solution is. I think the refrigerator on our 2006 Safari is dual operation but haven't had the chance to put it on a level surface to check it out yet. So whatever info you glean will be helpful should we run into this issue
Dana
Goal15 is offline   Reply With Quote
Old 05-06-2011, 02:06 PM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Deke, have you tested whether you have 110 in your rig? I just ask because it's the easiest thing I can think of. Even though the post is a 30amp post, is the circuit breaker on?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-06-2011, 05:01 PM   #6
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Originally Posted by dekew View Post
Hi all,
I have a Dometic RM3762 that works well - except the little propane light stays on when it shouldn't..................
I think we've checked all the obvious things - enough power (30 amp), no loose wires,..............
I believe mine has a plug that plugs into a 120 v. outlet that can be accessed through the access panel on the outside. Probably you have already checked to see if the fridge is plugged in. Also, check for voltage at this outlet. Otherwise, I like the direction that overlander63 has headed you.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 05-07-2011, 09:20 AM   #7
dekew's Avatar
Thanks for all the replies. I just went out and popped open the circuit box cover to find one of the black wires was loose. It must have rattled loose during the last move. Luckily, all I needed to do was re-seat that wire and we're back in action!
Old 05-07-2011, 02:10 PM   #8
Ready-to-Travel
pmclemore's Avatar
We all love happy endings. Congrats and thanks for the update.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
electric, fridge, propane, refrigerator
Propane phobia. ROBERTSUNRUS LP Gas, Piping, Tanks & Regulators 18 04-27-2011 11:37 AM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Propane go boom SpaceEgg LP Gas, Piping, Tanks & Regulators 4 02-28-2011 12:05 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Installing Propane light lucymcdog LP Gas, Piping, Tanks & Regulators 69 01-22-2011 11:12 PM
