Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Prev Previous Post   Next Post Next
Old 07-05-2009, 05:06 PM   #4
Profile:  1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Today I went over the propane line leading to the burner with an eyedropper loaded with soap solution--finally found the leaks (several). They are on the housing that the thermocouple activates, which has a push valve at the bottom for lighting the burner after it has been turned off. It looks like I'll have to replace that whole piece.
Any idea where I can get one? I just replaced the thermocouple itself, so I can probably salvage that.
26.982 amu is offline   Reply With Quote
New Dometic Refer Installation k9s2go Refrigerators 9 07-26-2006 09:46 AM
How to turn off Dometic refer? Vinoblanco Refrigerators 1 04-03-2006 11:34 AM
Dometic Refer Intermitent Richard Murphy Refrigerators 3 06-10-2004 06:45 PM
Dometic Refer question Mark Wiltrakis Refrigerators 5 04-03-2004 10:17 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 05:52 PM
