Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Prev Previous Post   Next Post Next
Old 07-03-2009, 10:43 PM   #1
Profile:  1972 29' Ambassador
1968 22' Safari
Tyler , Texas
Propane leak in Dometic 660 refer
My '68 Safari's Dometic refer fills the cabin with gas odor when it's on propane. The leak must be after the rotating valve that you access through the side panel to turn on the gas, since the smell goes away when I close that valve and use AC to run the refer (which doesn't do much of anything in the current 102 F Texas heat). I can't find the leak with bubbly soap. There is no yellow in the flame--it runs loud and blue. Where could the leak be, and how can I fix it?
26.982 amu is offline   Reply With Quote
New Dometic Refer Installation k9s2go Refrigerators 9 07-26-2006 09:46 AM
How to turn off Dometic refer? Vinoblanco Refrigerators 1 04-03-2006 11:34 AM
Dometic Refer Intermitent Richard Murphy Refrigerators 3 06-10-2004 06:45 PM
Dometic Refer question Mark Wiltrakis Refrigerators 5 04-03-2004 10:17 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 05:52 PM
