Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 09-11-2002, 08:58 PM   #1
Profile:
Propane fridge installation
I recently bought a 65 safari which had an electric fridge in place of the original gas/electric. I found an old magic chef gas fridge in an old 59 airstream. It works fine and I want to install it. My question is how do I ventilate the lower end to get good air flow to the top vent? the access cover does not have vents in it and the floor has had aluminum sheeting screwed on underneath where the fridge goes. Thanks in advance
Ted
yaakman is offline   Reply With Quote
Old 09-11-2002, 09:51 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Ted,
You will need to do some investigation but I think if you pull up the alumimum sheet that is screwed to the floor for will find the remnants of the air intake for the refer. Prior to 75 ( I think) intake air was drawn from under the trailer, later models had an external vent. You may have to pull another sheet of aluminum that will be obvious when you look underneath from the outside.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 09-11-2002, 10:06 PM   #3
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
fridge vent
Ted,
My 66 has a vent of sorts under the trailer from the floor where the refer sits. It also has a lockable door right behind the refer to allow access. The vent has a grille to keep out stray dinosaurs and a PO installed a filter there. I assume to keep down the dust. There is a vent in the floor behind the refer, just keep looking.
>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-12-2002, 06:59 AM   #4
Profile:
Thanks guys, A floor vent makes sense looking at the patch sheets of aluminum sheeting under where the fridge will sit. I will remove them and fabricate some sort of grill as it originally came with. Thanks again for the responses.
Old 09-12-2002, 07:26 AM   #5
Profile:  LOST , Hawaii
When you make your grill be sure as Action said, it does not do much more than keep out stray dionsaurs (I liked that). The cooling is a convection flow and it needs lots of open space. Something like 1/4" hardware cloth would work.
John
74Argosy24MH is offline   Reply With Quote
Old 09-12-2002, 07:34 PM   #6
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Smile Propane Rifer installation
The discription of the vents given are pretty much what I have in my '71 Int. Wire cloth 1/4". My Frig is an original Dometic.
Tom
niftypkg is offline   Reply With Quote
Propane Powered EU2000i? Pick Generators & Solar Power 6 01-22-2004 04:09 PM
First pipes now fridge... overlander76 Refrigerators 8 11-24-2003 02:46 PM
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 11:34 AM
fridge on when travelling? sjptak Refrigerators 2 06-16-2003 10:54 PM
Propane Usage COArgosy78 On The Road... 6 02-25-2003 10:35 PM
