Old 05-15-2002, 01:06 PM   #1
jlh
Propane/Electric Refrigerator
I have a dual powered refer. and it works ok electrically but not when using propane. I have opened the outside vent accessing the back of the refer. and checked the ignitor. I am getting ignition and gas flow. I also noticed that there is alot of rust accumalation under the flame arrester. Looks like the rust is coming from the heat exchanger that is fixed above the flame arrester. Could the heat exchanger be corroded to the point that it no longer functions or is there something else to check???
jlh is offline   Reply With Quote
Old 05-15-2002, 06:23 PM   #2
Refrigerator burners and flue's must be cleaned every year or two, depending on usuage. Everyone goes through the same problem that you now have. Be careful when you clean the flue, as there is a spiral twisted steel heat retainer, within the flue. You must remove it to clean the flue properly, and then reinstall it. The burner must be disassembled, cleaning all the rust particles that have settled in it or the mounting base, and then reassembled. A proper flame is a "MUST" for proper cooling. Just seeing a "flame" is not adequate. Andy
Old 09-19-2005, 11:39 AM   #3
1975 27' Overlander
Nelson , BC
how to clean the Flue Tube?
I read somewhere that we just need to tab the pipe with a screwdriver handle and then suck it with a vacuum cleaner. Is this right? Is there anything else we need to know or watch out for? We have a 75 overlander with a 98-99 Dometic Silhouette.
hubrik is offline   Reply With Quote
Old 09-19-2005, 03:15 PM   #4
No, it's not right. Andy describes the correct procedure in the previous post. Full details are at http://www.airforums.com/forum...lue+brush+nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 09-19-2005, 03:53 PM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I have just completed this task on my motor home. Attached is a link to Dometic with instructions and diagrams. I hope it helps you.
Welcome to the forum.
http://gasrefrigeration.net/dom_techdata/MAN_SM.PDF
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Refrigerator Problems - New Unit joshua32064 Refrigerators 35 08-01-2013 11:32 PM
65 Dometic Refrigerator, ignitor ChromeHome Refrigerators 10 04-24-2005 04:15 AM
Replace 110V Refrigerator Heat Element JimBrownUT Refrigerators 1 11-29-2003 01:41 PM
REFRIGERATOR; How to clean vent? 65 Dometic, ChromeHome Refrigerators 0 10-19-2003 10:04 PM
Refrigerator "Check" light on mcostanzo Refrigerators 5 06-27-2003 10:06 AM
