Old 04-11-2016, 07:38 PM   #15
1990 25' Excella
Tucson , Arizona
Its a 1990 Excella 25'
I will check it out on the internet.
Will let you know if its still working tomorrow.
winston10 is offline   Reply With Quote
Old 04-11-2016, 07:55 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Propane regulater issue?
Low water column values change the aspect ratio of the flame causing poor cooling. I experienced this last summer on my 91 with original fridgeall is.very cold.again!
Old 04-11-2016, 08:08 PM   #17
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I will agree with the before mentioned remarks. Airflow is the key.
This is what I did and cured the problem!
ID:	260511   Click image for larger version
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 04-11-2016, 08:47 PM   #18
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
where did you get the vent cap.
Lets travel is offline   Reply With Quote
Old 04-11-2016, 08:56 PM   #19
1990 25' Excella
Tucson , Arizona
Hey, this is great.I'm going to have something to do for a couple of days.
Keep it coming.
Old 04-11-2016, 10:28 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The model of the coach is not what you want. You need the model of the refer. RM xxxx for example.
Old 04-12-2016, 05:57 AM   #21
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by Foiled Again View Post
I live in beautiful coastal Virginia - 99% humidity any time the temperature goes above 70 degrees.
I knew that almost all RV refrigerators need to be defrosted periodically, but I've run into a lot of younger people who simply never had an old refrigerator and can't imagine black and white TV's or computer monitors. They wonder what that huge lump of ice is in the top back side of their refrigerators and why the unit seems to not be cooling as well as it used to.
An hour later, after removing all of the food, turning off the fridge, filling a bucket with Ice sheets and dripping water and using a hair dryer to break up the icebergs - their refrigerator is ready to work again, and work WELL.
I once suggested to some one to try that and they were adamant that their fridge was a frost free and something had to be wrong. The freezer 1/4 full of ice totally confused them. They called a mobile repair man. The first and only thing he did was turn off, empty and defrost the unit. It worked 100% after that. My advice, free. His $200.
Old 04-12-2016, 01:07 PM   #22
1990 25' Excella
Tucson , Arizona
TG, Started frig.yesterday at 1:30 pm checked this morning at 10;30 am.It was 33.It was 70 here today.I think the problem was the temp.at 98 and no air moving.Cleaned all contacts.Model # is 2620 Dometric.Might leave the outside door open & get a small fan when its hot.
If that doesn't work I will check other suggestions.
Thanks for all the suggestions.
Old 05-01-2016, 10:06 AM   #23
1990 25' Excella
Tucson , Arizona
To date this is what has been done.
Made a manometer & the water column is 12 lowed to 11.
Installed battery operated fans.One in rear of fridge towards vent,vent is clear.
Another in the fridge to circulate air.
As stated cleaned all contacts.
Best I can get is 33 morning & 45 afternoon with afternoon temp. at 85.Not opening fridge.Running on propane.
Is this the nature of the beast or can I do better?
Normetric 2620.
Ray
Old 05-01-2016, 10:32 AM   #24
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Your gas is too low. Needs to be 14-16" wc.
I went through this 2 years ago. Increased my regulated to 15-16" wc and cooling is great again!
Old 05-02-2016, 05:02 PM   #25
Venice , Florida
Images: 14
Refer to POST #17
Sorry not to more specific at the time. This is a solar fan I stalled. Requires no electricity except for the sun, that is the time when the air circulation is needed the most. It is switchable inside the cabinet adjoining the frig inside the cabin.
Airdreamers
WBCCI #8880
AIR #41310
Argosy refrigerator problem ? Davis Refrigerators 5 01-21-2015 07:22 AM
Compact Home Refrigerator or RV Refrigerator? Truebrit Refrigerators 26 04-05-2011 01:30 PM
Silly Dometic refrigerator "problem" Toasty's Dad Refrigerators 0 12-20-2005 07:19 PM
Refrigerator Replacement Size Problem Herritt Refrigerators 4 05-04-2005 11:47 AM
Refrigerator Problem bken Refrigerators 2 04-26-2004 09:46 AM
