Old 06-16-2012, 11:14 AM   #1
2005 22' International CCD
Buckhorn , Ontario
Please help...
Hi again - Not sure what my fridge model is in the 22' ccd but it is the original.
I have it set at 4-5 on electric and the fins are frosting up badly.
What could the problem be and how might I fix it?
05ModPod is offline   Reply With Quote
Old 06-16-2012, 11:26 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The first thing I would check is the door gasket. There has to be a continuing source of moisture to feed the frost.
Yes some frost will form but if the Frig ever reaches the set temperature that frost will melt before the next cycle is started. Assuming you are not attempting to use the frig as a freezer
2004 Excursion 4x4
Old 06-16-2012, 12:14 PM   #3
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
There's some great fridge troubleshooting info online at
rvmobile.com
