Old 01-26-2016, 07:33 AM   #1
woodhaven , New York
Pilot valve overlander
Hi all. Would anyone know where to buy a replacement valve for refrigerator pilot light in 59 over lander
the one that keeps the gas flowing when the pilot is lit (looks like wire attached to diaphragm type valve) thank you.
rick670 is offline   Reply With Quote
Old 01-27-2016, 10:53 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Photos would help. It sounds like you have a conventional gas valve, not the earlier "Klixon" style. If that is the case, you may be better off replacing just the thermocouple (the part that looks like a copper wire). Replacement thermocouples can be purchased at almost any hardware store or home center.
Old 01-27-2016, 03:33 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There is no pilot in your refer. It is just a burner. If you can light it and the flame goes out when you release the override it may be a bad thermocouple or bad connection where the thermocouple is screwed into the gas valve. It is only a 20millivolt signal. Make sure the contact area is clean.
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
Gas leak at oven pilot valve - 68' Magic Chef AirstreamPDX LP Gas, Piping, Tanks & Regulators 1 08-28-2015 11:24 AM
Honda Pilot for towing 1955 Overlander? 55Overlander Tow Vehicles 2 07-12-2014 06:10 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
Traveler Stove: valve? pilot? hello? is this thing on? Slik Stoves, Ovens & Microwaves 2 06-13-2004 02:59 AM
