Old 09-24-2006, 03:03 PM   #1
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Fallbrook , Southern California
Send a message via Yahoo to abridges01
Pilot light won't stay lit
The Dometic in our '76 Argosy MH appears to work fine on AC, but I cannot get the pilot light to stay lit. As long as I hold the knob out in the lighting position, I can see the pilot is lit with a nice blue flame, but as soon as I release the know, the pilot light extinguishes.
The stove and oven work fine so I am confident the propane is fine. I removed and cleaned (a very rusty/dirty) baffle and did my best to clean the flu, but no change.
Any suggestions? Anything... please We are off out next week and a cold propane driven fridge is essential... see dear, I told them just like you said
Cheers,
Andrew
1975 26' Silver Argosy MH: Ethyl the Never Ready!
Fallbrook, Southern California
"Experience is something you never have... until just after you need it!"
abridges01 is offline   Reply With Quote
Old 09-24-2006, 03:10 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It may be the thermocouple. We had a guest here in a Casita with the same symtom. We got a new thermocouple, installed it (10 minute easy job), and all was great.
By the way, we also discovered that there were two differences between the residential and the RV termocouples:
1. The residential was longer. It could have been coiled and used in the RV.
2. The RV thermocouple was about twice as expensive and available only at the RV outfit; we could have bought the residential at the corner hardware store.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 09-24-2006, 03:38 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I had the same thing in my '76 Overlander. I changed the thermocouple and still had the same thing going on. Andy at Inland said to tighten it "really tight". After I did that, it stayed lit. I had to order the thermocouple from an RV store here because the end on the one from the local hardware store didn't fit the connection properly.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-24-2006, 04:19 PM   #4
steelbird312's Avatar
2013 31' Classic
Crossville , Tennessee
Images: 11
Andrew, It probably IS the thermocouple. This "tells" the gas valve to stay open because there is a fire where it needs to be. They do sometimes go bad. They also sometimes will have corrosion buildup where they are connected, and they sometimes get hit, and knocked out of the flame, preventing it from getting hot and giving the message to the valve. Look at it while holding the button, and ensure it is in the flame. If that isn't it, then remove it and clean anything that attaches to something else. If that doesn't do it, get the one at the hardware and see if it will fit. If all that fails, buy the high priced one!
steelbird312 WBCCI #6673 jerry Hodge
2013 31" Classic limited
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand, throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 09-24-2006, 09:26 PM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Tighten it really tight
Make sure the connections are tight prior to buying another. Think of it as an electrical connection.
Fyrzowt is offline   Reply With Quote
Old 09-25-2006, 12:01 AM   #6
76 Silver Argosy
abridges01's Avatar
1975 26' Argosy 26
Thanks everyone, tightening the thermocouple, plus fifteen tear downs and reassemblies appear to have done the trick.
I cannot stress how good it feels to know that such sound advice and knowledge is so easy to hand, I thank you all.
Cheers,
Andrew
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 06:25 PM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 01:04 PM
Ref pilot Dbraw Refrigerators 2 08-27-2002 05:43 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 12:03 PM
