04-16-2008, 02:37 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
Pilot error?
My 1976 Argosy 20 has been a champ. While commissioning this past weekend, I found the pilot light to be strange. Instead of getting a nice blue flame at the end of the large, elbow-shaped tube, I'm getting a chaotic orange flame where the air holes are located at the beginning of the tube. It doesn't heat the thermocouple (perhaps thankfully) and consequently won't gun on gas. Have fuel, stove and furnace work fine. Electric operation is good also. Any tips? Clogged pilot tube? Screen is in place. Help.
Happy when I'm rollin',
Nick
WBCCI#3528
04-16-2008, 02:49 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Have you checked for....
Get some pipe cleaners and clean out the inside of the flow tube. That's the first place I would start.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
04-16-2008, 03:51 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
WHOA!!! I'll get some pipe cleaners and a baseball bat. I hate spiders, more than snakes. Is the flow tube this elbow shaped baby I'm looking at?
Nick
WBCCI#3528
04-16-2008, 03:56 PM
Naples
Nick,
A word of caution......................
When you are cleaning out your LP burner and feed tubes, be especially careul of the tiny little gas orifice at the end of the LP tube attached to the gas valve. This is a precision deilled opening and NOTHING should be put thru it except compressed air and maybe carb cleaner and then air. Anything solid can and probably will deform his hole and require you to get a new one.
lewster
04-16-2008, 04:36 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
Have pipe cleaner...will ream.
Wire Palladin
San Francisco
Nick
WBCCI#3528
04-16-2008, 04:43 PM
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge
Many units have an adjustment screw (some where in-line from the regulator to the out flow) that adjusts the gas flow... I find the more gas the more air contact the more orange the flame becomes in color... the less flow the more blue the flame becomes...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
04-16-2008, 05:17 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
Thanks Rick and Lew,
Found light,white cobweb(?) below the screen at end of pilot tube. Easily disrupted with fine copper wire. Nice blue pilot flame there now...but still getting flame at vent holes at other end of P.T. Is this bad? Doesn't seem right. There is an orifice just upstream of these holes. Can I go back in and pull the screen off to get more cleaning inside? At what point am I in the market for new tube?
Nick
WBCCI#3528
04-16-2008, 05:55 PM
Naples
Pull it, clean it and try again. You might be getting some back-flow of LP from the end of the burner supply tube. You also might be out of adjustment at the gas valve (assuming that your valve is adjustable and has a pressure port)
You will need a manometer to read the LP pressure, and the appropriate fitting to attach to the little set screw that covers the threads of the pressure port. You should be reading 11" water guage with 50% of the LP appliances running. The stove and this unit would suffice. You then adjust to 11" and you're good to go!
lewster
04-16-2008, 06:07 PM
2001 34' Limited S/O
Moyock
, North Carolina
I think there is a thread in here as to how to make a manometer, I copied it at some point but not sure where I put it. when you finally get it clean put 1/2 dog flea collar in the compartment this will keep the spiders and their mites out. Replace twice a year, cheap ones work as good as expensive ones.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
04-16-2008, 06:10 PM
1969 23' Safari
New Orleans
, Louisiana
I found a manometer on ebay for around 25 bucks...old style that you fill yourself but works fine..fyi
04-17-2008, 03:42 PM
1976 Argosy 20
1997 34' Limited
Great Barrington
, Massachusetts
Muchas gracias, Amigos.
She's burnin' true blue and no extraneous flaming. A can of "dust remover" blew out the cobwebs and cleaned the orifice. Su-weet! You guys are the best. I figure if I paid me Airstream prices, it was a $240 job. Of course, who would pay me $85/hr.?
Nick
WBCCI#3528
04-17-2008, 03:52 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
Wire Palladin
San Francisco
Good one!
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
04-17-2008, 04:04 PM
Naples
Hey! $85 is a good rate!! You should see what they charge in FL and CA .
lewster
04-17-2008, 06:16 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
...since you mention it, how much? ;-)
Ricky
04-17-2008, 06:46 PM
Naples
Depending on who you ask......................$110-135/hour.
lewster
04-17-2008, 08:20 PM
1978 31' Excella 500
Venice
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
404 Error
sigv |
Forum Admin, News and Member Account Info |
69 |
12-21-2007 10:45 AM |
Speedometer error
silver buffalo |
Mechanics Corner - Engines, Transmission & More... |
2 |
10-09-2006 10:54 AM |
Error messages
streamer23 |
5 |
08-28-2006 12:26 AM |
