Old 03-08-2010, 07:36 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Picture of refer vent
Can anyone post a pic of how the fiberglass refer vent hooks up to the roof for mid 60's AS?I have a couple of pieces loose and I want to see if I have them all.
bwaysteve is offline   Reply With Quote
Old 03-08-2010, 07:50 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Do you mean the vent, or the vent cover? Is it the interior scoop, or the outside part?
Old 03-08-2010, 08:24 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
refer vent
Terry,
The top opening has been sealed with a patch and an elec. refer unit used.I have an oval insert that fits in the hole and a fiberglass scoop that I removed from the wall.It had maybe a foot cut off the bottom I assume to make room for the elec. unit.
There was nothing metal behind it(just vinyl wall) should there have been?Thanks.
ID:	97742   Click image for larger version
ID:	97744   Click image for larger version
Old 03-08-2010, 08:50 PM   #4
Well Preserved
1993 21' Sovereign
Originally Posted by bwaysteve View Post
Terry,
No, just the scoop against the wall. The oval insert goes on the roof, and the cover goes over that.
Old 03-08-2010, 09:32 PM   #5
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Do I need to fiberglass the missing bottom? It looks like about 8 in. is cut off.
Old 03-08-2010, 09:41 PM   #6
It vents the back of the fridge to the outside. As long as you seal around the back of the fridge and up to and around the vent opening so all of the blow off from the fridge goes up and out, you should be fine.
Here is our blog when we rebuilt the cabinets around the fridge and sealed the vent scoop up:
http://www.airforums.com/forums/blog...ce-galore-656/
We used a gasket where the shelf above the fridge sealed to the vent scoop, silicone sealer (although not what was originally used) to seal the separating walls on each side of the fridge to the interior shell and foam seals around the fridge between the separating walls and sides/top of the fridge. This will push any gas from the back of the fridge either out of the access door vents or up and out the top vent.
Old 03-10-2010, 06:42 PM   #7
Steve,
I found some photos of our fridge and vent after removing the original walls but before the new to show you the seal that went around the fridge (little hard to see but...). Look in these photos and you can see the strips of wood that ran up the sides of the fridge. They also ran along the top. These had foam with stickers on one side that stuck to this strip. Then when the separating walls were put on each side and the shelf above, the foam made a seal. Then seal the separating walls to the aluminum trailer sides and shelf against the scoop.
Please disregard the mess... what a mess it was.
Old 03-10-2010, 06:47 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Although the refer for the 65 is a smaller one approx 42 in'? I get the idea as to how this fits.Thanks for the pics.
Old 03-11-2010, 05:07 AM   #9
Arrowstream's Avatar
Columbia , South Carolina
Here you go:
Arrowstream is offline   Reply With Quote
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
Refer vent screen or not? geezernbabe Roof Vents, Skylights & Fans 5 01-19-2009 06:51 PM
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 03:24 PM
New refer. 77caravaner Refrigerators 1 10-31-2002 11:04 AM
