Old 08-05-2007, 02:07 PM   #1
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
part 2
We went over 4,000 miles in our safari w/the recently recalled dometic refrig fix..the refrig worked fine all the way throughout the trip..came back home, unplugged it from the 12 volt..and it never came back on when we switched over to the electric system!..the a/c works. Does anyone have any suggestions they'd like to share?..thnx
codybear is offline   Reply With Quote
Old 08-05-2007, 02:18 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome back Paula. Sounds like you and Steve had a great trip.
What do you mean you disconnected it from the 12 volts?
If you unplug shore power will it run on propane?
Richard
Old 08-05-2007, 02:21 PM   #3
codybear's Avatar
1964 22' Safari
Images: 315
Hi Az, Steve say the controls won't even come on ..and the control panel runs on the 12 volt..he says that is charged up..according to the battery charger. but still should come on it on ac, right?
Old 08-05-2007, 02:54 PM   #4
2002 25' Safari
Dewey , Arizona
Images: 62
If you had the original fridge that came with your trailer (if it worked), this would not be a problem. The newer units need 12 volts to run the circut board. Without the 12 volts it is dead. Steve needs to meter the 12 volt line to the fridge. It could be just a blown fuse. Do other 12 volt items (lights - water pump) work?
Richard
Old 08-05-2007, 05:14 PM   #5
codybear's Avatar
1964 22' Safari
Images: 315
We fixed the problem..it was a loose wire that came off the battery. 12volt to the refrig..must have come off just as we neared home..thnx!
Old 08-05-2007, 05:41 PM   #6
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Well if it's going to break, that was a good time. Glad it was simple.
Welcome home.
Dave
Fyrzowt is offline   Reply With Quote
Old 08-05-2007, 05:44 PM   #7
codybear's Avatar
1964 22' Safari
Images: 315
Hi Dave,
More things to remember our trip by!!!!..stay tuned for the best snafu!!
Old 08-05-2007, 05:47 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
Wow, there is more!
Richard
Old 08-05-2007, 05:51 PM   #9
codybear's Avatar
1964 22' Safari
Images: 315
Of Course, Az, what's life w/out a little ups and downs, and offs and ons?..
Old 08-05-2007, 05:53 PM   #10
Fyrzowt's Avatar
2000 25' Safari
Images: 8
Hmmm, Holding my breath.....hurry....
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
what is the MOST you have payed for an airstream part? part2 overlander Our Community 3 11-26-2002 01:49 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
