Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 11-15-2005, 03:04 PM   #15
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Originally Posted by ankornuta
I'm going to have to bring not only a generator, but also a portable air-conditioner. Unless I decide to avoid camping in Arizona in the summer altogether
White Mountains, Big Lake, WM Apache Reservation etc, no AC required
Richard
Charter Member Four Corners Unit
Old 11-15-2005, 05:36 PM   #16
ankornuta
ankornuta's Avatar
Profile:  Currently Looking...
Lowell , Massachusetts
Images: 22
SafeHarbor: My intent is to restore this trailer back to its original condition, and while some units had A/C in 1958, this one did not. It was built in CA and purchased by some folks in Oregon.
AzFlyCaster: Very true! We have some property up in Eagar, AZ. Not too far from Alpine which has just great weather in the summer, so long as there aren't too many fires And Bear Wallow cafe is there in Alpine. They have the best patty melts ever. Between the patty melts and the weather, it's well worth the drive.
ankornuta is offline   Reply With Quote
Old 11-16-2005, 07:49 PM   #17
ankornuta
ankornuta's Avatar
Images: 22
Restoring the "guts"
One of my business partners owns and A/C company and will be testing and possibly recharging the freon on the refrigerator, but while the body is being restored, I had to find a way of suspending the freezer compartment at approx the right height above the condensor and compressor so as to not accidentally break the capillary tube. So I built a little frame to hold it up and now I can move it around without having to ask Max to come out and help me every time.
I think I might have too much time on my hands
ID:	16413  Click image for larger version
Old 01-17-2008, 07:16 PM   #18
NorCal Bambi
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Marvel fridge question
ankornuta, howdy this is NorCal Bambi in northern California. We have just found a 50's Marvel R12 electric fridge. How did your restoration go? I'd like to restore this one. Maybe even convert it to propane electric. Do you have any suggestions and or names of parts suppliers.
Thanks Don
NorCal Bambi is offline   Reply With Quote
Old 01-17-2008, 08:28 PM   #19
markdoane
Profile:  , Minnesota
Images: 59
Don,
You might send a PM to n2batr. He bought the trailer from Andrew several months ago.
Non-contributing deadbeat.
Old 01-18-2008, 01:21 AM   #20
Kajtek1
Kajtek1's Avatar
Profile:  1965 22' Safari
Orinda , California
You can power 120V fridge with inverter, while on the road.
It takes 10-15 amps at 12V so 30 amp trailer plug in TV is pretty sufficient.
Can't convert freon fridge to run on propane.
Kajtek1 is offline   Reply With Quote
Old 01-18-2008, 06:57 AM   #21
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
The refrigerator tear-down is complete. I've decided to keep the original compressor and "guts", but I need to find someone to restore it for me. I think rebuilding an ammonia-filled compressor is a little beyond my skill level. Do people still restore and work on these things? Are they legal?
List of scary substances discovered in my Airstream so far:
- Asbestos
- Ammonia
- Fiberglass insulation (scratchy!)
Here's a pic of the guts. I almost broke that little copper pipe and then I'd have ammonia all over my garage... That's the freezer compartmenet setting on the red stool. The cooling coils only run around it. It also has these two large pill-shaped wide points on the pipe that comes from the compressor. I wonder what those are for?
From your photo in this post, you definitely have a compressor type fridge, which has probaly R-12 refrigerant in it......NO AMMONIA. Ammonia asorbtion refrigerators require HEAT to operate, and if it was an absorbtion type, you would have a heat source like an electric heating element or LP burner attached to a boiler tube and lots of funny, angled tubing and a chimney vent.
This should be a much easier re-build than an ammonia type.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 01-18-2008, 09:06 AM   #22
ankornuta
ankornuta's Avatar
Images: 22
Hey Don. I ended up selling the trailer when I moved to Manhattan for work. A nice guy up in Wyoming has it now and he's on the forums. It looks like he re-tore the trailer down and is doing it from the ground up. I'm excited to see how it turns out for him!
As far as the fridge goes, after really evaluating the type of camping that I would be doing and realizing that I would be off-grid more often than not, I had decided not to restore the fridge afterall but instead to find a new refrigerator which I could mount the old doors too so that it looked vintage, but operated like a new two-way unit. I really think that's the best way to go, to be honest.
If you're dead-set on keeping the old unit, get to know a good HVAC/R guy. One of my business partners in Arizona built wine-cellar cooling/humidity control units and he told me a great deal about how to restore and rebuild these old units. It's pretty much all custom and I didn't find any good resources online.
Hope this helps!
-a
Thanks Don
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
Original LOOKING interior lights for vintage trailers flamingo-kid1 General Interior Topics 0 04-18-2004 09:04 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 4 10-26-2003 06:10 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 3 09-07-2002 08:27 PM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 01:00 AM
