Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 03-13-2015, 02:23 PM   #1
2006 28' Classic
St. Francisville , Louisiana
Odors in the freeze
To the point,someone left a pack of meat in the freezer after it was turned off.How can I get the smell out, I tried everything. It still smell!
Help.
johnlanglois is offline   Reply With Quote
Old 03-13-2015, 02:37 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Here are a few options that hopefully help
If food has been allowed to spoil in a refrigerator or freezer, the strong odors associated with food spoilage may be extremely difficult to remove.
1.The first step is to clean the appliance with a gentle household cleaning solution and water. Use a bleach solution (one tablespoon chlorine bleach per gallon of water) to rinse inside surfaces. While the unit is turned off, leave the door open for a day or two to air it out. Spray disinfectant around hinges and locks and into any openings. If the odor remains, try one of the following methods:
2.Place trays of activated charcoal, clean kitty litter or baking soda on the shelves of the refrigerator or freezer. Run the appliance empty for 2 or 3 days. Activated charcoal can be purchased from stores that sell aquarium and terrarium supplies.
Place freshly ground coffee on cookie sheets in the refrigerator or freezer and close the door. Again, run the appliance empty for 2 or 3 days. A slight coffee odor may remain, but will disappear after washing and rinsing.
3.Pack each refrigerator or freezer shelf with crumpled newspaper. Set a cup of water on the top shelf or sprinkle the newspaper with water. Allow the refrigerator or freezer to run for approximately 5 or 6 days. This method is time consuming, but effectively removes strong odors.
4.Several commercial products are available for removal of refrigerator and freezer odors. These products may be purchased at hardware, grocery, discount and variety stores.
5.If the unit has been off several days, it is possible the odor has gone into the insulation. If the odor has penetrated the insulation, much work is needed to get it out. An air compressor might be needed to blow air into various sections of the unit. If the above methods did not satisfactorily take care of odor problems it may require service of removing the main door taking it apart and replacing the insulation that is tucked in between the doors shelves. The screws for taking the door apart are hidden under the gasket, just pry the gasket back and unscrew.
thesignlady is offline   Reply With Quote
Old 03-13-2015, 02:48 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Peppermint Oil. After a deep cleaning, put a few drops on cotton balls and place in compartment. It works wonders on nasty smells plus no more ants or mice.
MICHAEL
Old 03-13-2015, 03:20 PM   #4
1963 19' Globetrotter
Orion , Illinois
Wet newspaper
We had the compressor fail on a new refrigerator while we were on vacation for a week. Lots of spoiled meat in it and an odor that was beyond belief and that I thought would never come out. The manufacturer advised us to take crumpled pages of newspaper wet it down and fill the freezer section with it and to put a bunch in the bottom of the refrigerator as well. We changed the paper every day or so in in about 10 days the odor was gone.
63air is offline   Reply With Quote
Old 03-13-2015, 03:40 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I'll add one idea, though some of the others already suggested should work:
Wash thoroughly with white wine vinegar. That's also my go-to solution for washing the fridge before placing the Airstream in storage, because it inhibits mold growth.
Old 03-14-2015, 08:30 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Use hot water with Clorox and wipe it down a few times, works every time.......
Old 03-14-2015, 09:10 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Vanilla extract wiped over the entire interior surface is a time proven cure for stink!
Old 03-14-2015, 10:31 PM   #8
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
I was an appliance technician for 13 years before teaching appliance repair at a tech school for 25 years. Trust me, this will work.
First wash with a baking soda paste. Then rinse very well. Then let dry. Then, like you are waxing a car, spread on a thin coat of a mint tooth paste. Let that dry at least 24 hours. Then wipe it off with a dry towel.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-14-2015, 10:52 PM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
...hydrogen peroxide solution ... diluted - a bit less offensive to your nose than bleach ... non-toxic with no bleach residue.
Old 03-15-2015, 09:31 PM   #10
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
Stuff with crumpled newspaper. It will absorb all the smell. Works all the time in real estate.
1972 Airstream International Land Yacht Sovereign
mrrealtor is offline   Reply With Quote
Camper has "ODORS" Help Please hardwoodjdc All Argosy Trailers 39 11-15-2014 04:04 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Occasional stale air /Odors inside the TT jm2 Dehumidifiers & Ozone Generators 4 08-02-2011 08:00 PM
Sewer Odors with Fantastic Fan TBRich Waste Systems, Tanks & Totes 37 01-09-2008 01:47 PM
Newer model odors/fumes janetb 2007 Safari SE 26 03-01-2007 10:28 PM
