Old 06-11-2019, 08:49 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Norcold 305r won’t cool...ruining Disney trip
Norcold 305r will not cool much below 50 degrees. This unit was just meticulously installed last summer after our original 1964 Dometic died. I did the install to their spec sheet.
Cooled to freezing at home in the driveway. Lynn packed and all seemed well. We boondocked in a Walmart for the first time excited to finally live Wally’s dream free from hookups.
Fridge was right around 40 degrees in the morning. We felt we were doing great! Last night at our electric site when running on electric, it was barely 50 degrees. We can’t get it colder.
We already 1) bought an internal circulator fan from Camping World enroute today 2) shuffled all food to give more air circulation 3) ran a fan at access door outside to force hot air up the chimney 4) placed expensive Disney ice in the fridge to try to lower temperature.
The only thing we can think of is we overpacked it. The heating element in the back is hot. I burned three fingertips touching it. Interior fins do not seem cold.
On a two week trip at Fort Wilderness. Does anyone have any suggestions?
We may buy a cooler and tough it out...but we wonder, why spend all this money and TIME redoing a vintage Airstream if we can’t use it the way we should be able to? Can a one-year-old Norcold be dead already??
PA BAMBI II is offline   Reply With Quote
Old 06-11-2019, 08:55 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Sorry for your troubles. As a pragmatist, I’d go the cooler route as a relatively inexpensive way to redeem the reason you’re on vacation and save the fridge problem solving for later. And you can reuse the cooler in lots of other situations after this trip.
Hopefully someone with more knowledge about your fridge will chime in with helpful answers for you.
Old 06-11-2019, 09:01 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I agree. Buy the cooler and move the critical stuff to it. Then see if the fridge can “catch up”. Maybe just a matter of overloading it and not enough down time with door closed.
Dept of “OverKill”
Old 06-11-2019, 09:04 PM   #4
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Any unit of any type can fail at any time. At a guess I'd suggest ventilation of the hot coils in back may be insufficient, so I'd keep working that angle. Might be worth reaching out to Norcold customer service if you haven't already done so.
Meanwhile, given the objective is to make the trip a success right here right now, I'd add a good cooler to the mix. You can either go with a quality cooler (doesn't have to be a Yeti, but should promise to keep ice for ~6 days), or a powered cooler that operates via a Danfoss compressor. The latter would be more expensive, but you wouldn't need ice.
Best wishes for a happy and successful visit!
Rocinante is our 2014 International Signature 27FB
Old 06-12-2019, 01:19 AM   #5
Long Island , New York
Sorry for your troubles. Probably a combination of factors IMO, including some "bad news" items.
What were the ambient outside air, and trailer interior temps, during all this? If you loaded in PA and ended up in FL, the outside and inside temps have been increasing, right? How hot has the trailer interior been? A/C working OK?
Which side of the AS is the fridge on, and was this side in the sun? Under an awning maybe for the midday sun?
Over-packing probably made things worse. So does adding ANY room-temp item into the fridge. We always have a couple of coolers in our van tow vehicle . . . one to store ice . . . and one to pre-chill liquids etc. before adding them to the AS fridge.
RV fridges have trouble in summer. Period.
They can only be counted on to lower the ambient air temp roughly 40 degrees or so. If the outside air is 80, no prob. If the outside air is 90, well the math is easy. Did this factor affect you? What is the air temp at Disney right now? Looks like the daily highs have been close to 90, is this correct? Is the fridge side of your AS in direct sun? In effect, your new fridge may be in an oven.
Setting off with a new untested fridge is another factor which did not run in your favor IMO. Sorry, but this had to be said. Especially for a different model and/or cooling system. Install-test-adjust-test-etc..
Traveling without a back-up cooler . . . another factor.
Good luck,
Peter
PS -- At this point your solution should be KISS . . . one or two coolers, and plenty of ice. Life delivers the lessons we need to learn. New fridge and hot location . . . new lessons.
Old 06-12-2019, 03:47 AM   #6
1964 17' Bambi II
Good luck,
Peter
Peter, good insights. The ice we placed in there overnight has lowered the temp considerably. Maybe it will be able to catch up.
This Norcold is not untested. We have had it out twice this summer...once to the Jersey Shore where it is, not totally unlike Florida, hot and muggy. The fridge did fine. We used it a few times last season after the original failed.
Then last time we did Florida two summers ago, I had just gotten the original 1964 Dometic operating. I brought a cooler on that trip just in case the 50+year old unit didn’t survive the trip,. Didn’t think I would need it this time.
Old 06-12-2019, 05:21 AM   #7
Thanks for the update, and for your graceful reception of my middle-of-the-night wanderings.
Have fun at Disney!
Peter
Old 06-12-2019, 09:26 AM   #8
eagletoo's Avatar
2019 23' International
PA BAMBI II,
While at the Fort last summer, my neighbor called Norbert to fix his A/C. Very competent, friendly and fair priced, we thought after the repair.
Give him a call, if only to see what’s what with your fridge. His repair truck’s contents are a thing of beauty!
Masters RV Mobile Service - Norbert
112 Celava Court
Kissimmee, FL 34743
Phone Number: (407) 348-0862
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi with factory towing package
Equal-i-zer Hitch
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 06-12-2019, 09:47 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I don't know about your fridge, but on my Dometic there is a little clip with a wire on it (temperature sensor) clipped to the fins on the inside. Check to see if you have it and if so the higher up on the fins it is, the cooler the fridge runs. Maybe loading or travel dislodged it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-12-2019, 10:50 AM   #10
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Have you tried running the fridge on propane instead of electricity?
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 06-12-2019, 10:57 AM   #11
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
Just a thought fellow Bambi II owner. If your trailer has the original frig fresh air intake in the floor make sure there are no obstructions. We closed off that intake because of all the refuse it collected and made a new intake in the outside wall behind the frig.
I’d post a photo but used up my allotted photo space years ago.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 06-12-2019, 11:04 AM   #12
Magnet18's Avatar
Churubusco , Indiana
+1 on the temp sensor check
I've never heard of over-loading causing a fridge to not work, usually the opposite, more thermal mass makes them better (once that mass is cold)
Does this have a separate freezer?
If so, what's the freezer temp doing?
Is there any baffling in the chimney? i.e. is all air forced through the cooling element, or can some air go around it?
Try different power sources, my parents norcold is fine on 110 and propane, but barely works on 12V
I've also seen a fridge stop working on propane... Because the regulator was just replaced, and the new regulator was a dud
Also check for model recalls
As an aside, if this "ruins" a trip, you really need to reevaluate some life philosophies and gain perspective
I'm sure you weren't being serious, just saying
Edit, also, whoever said an RV fridge can only lower temps 40 degrees makes no sense. We full-time, and our dometic fridge/freezer in our 40 year old airstream has no trouble on 100 degree days in direct sunlight.
Ironically the only time it has struggled was when it was -20 out, because the ammonia froze in the pipes
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 06-12-2019, 02:31 PM   #13
1985 31' Excella
Lindrith , New Mexico
Get a cooler and/or go to McDonalds.
Horsedogcat5 is offline   Reply With Quote
Old 06-12-2019, 05:19 PM   #14
1999 28' Excella
Lake Mary , Florida
Go to nearest Publix and buy a few pounds of dry ice. Handle like it is nuclear fuel. Put it on a piece of styrofoam in your freezer.
suncoasteng is offline   Reply With Quote
My Disney/Fort Wilderness Trip AldeanFan On The Road... 40 03-13-2016 02:37 PM
11th Trip to Disney World TomW On The Road... 18 10-08-2015 02:21 PM
Help? CA DMV is ruining vacation Michael Good Title, VIN & Registration 5 07-09-2011 07:18 PM
When changing shocks to prepare for trip to Disney... tenrsingr Repairing/Replacing Floor &/or Frame 7 04-07-2010 04:41 PM
carrier v low cool vs high cool joewinfield Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
