07-31-2014, 12:53 AM
Moscow
, Idaho
Noob Airstream Owner, can't get fridge to work
Hello Friends,
I just purchased a 1974 31' Sovereign and I can't get the fridge to turn on!
It was working when I bought it two days ago...
When I switch to electric nothing happens. When I switch to gas it lights and the transparent indicator turns a nice blue, but still nothing....
Here are a few pic of my fridge.
Thanks for the help,
C
07-31-2014, 04:46 AM
1993 34' Excella
York
, South Carolina
It will take a few hours, even overnight, before you can notice the cooling. There is no compressor, or noise to listen for. Be sure to keep the coach relatively level any time it is on.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
07-31-2014, 05:03 AM
Portsmouth
, Virginia
I had that fridge before I replaced it with a newer version. Go outside and open the access door. You should be able to see the flame on gas and should feel the piping in the back getting warm to hot. These fridges work on evaporation of ammonia gas by using a fairly small heat source of either a pilot light flame or a 110v heating element. As John mentioned, they take a good day to cool down adequately, and generally make no noise.
On electric, make sure the fridge is plugged into an outlet (should be one behind the fridge) and verify that there is power to it. After a while you should feel some heat as well. Sometimes the elements burn out and can be replaced. On mine, the element had burned out and was essentially rusted in place. Thats why I replaced the fridge, so I could run on electric.
07-31-2014, 06:45 AM
1999 34' Excella
Hillsboro
It uses ammonia. If you have a leak you will smell unless it has dissipated.
There are several sites describing the "absorption" method these fridges use.
If you need help finding let us know...
Peace and Blessings..
Channing
WBCCI# 30676
07-31-2014, 08:46 AM
1974 Argosy 26
Morrill
, Nebraska
The refer must be level. Especially front to back in the coach.
Check for level on the freezer floor.
Is the gas thermostat set to at least 5 on the dial?
07-31-2014, 04:07 PM
Moscow
, Idaho
You all are fantastic! All hope is not lost. I'm going to leave it on overnight and cross my fingers. I thought I would have heard a compressor or noticed a temperature change relatively quickly.
Thanks again! I'll let you know what happens.
07-31-2014, 10:52 PM
1999 34' Excella
Hillsboro
To speed up things you can put already Cold items in. We have a small fan that circulates the air inside. It helps ! We put in rear of fridge near the coils. Make sure Fridge is level!! The ammonia most be level for best performance. If in the sun you may have tough time getting max cooling.. Also check that the roof vent is not obstructed.
Channing
WBCCI# 30676
07-31-2014, 11:24 PM
1978 31' Excella 500
Genoa
, Nevada
There's a metal plate in the freezer, watch the temperature of that, it's on the cooling coils and will tell you what's up. That plate is what you level the trailer to.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
08-01-2014, 10:43 PM
1999 34' Excella
Hillsboro
Sooooo. Do we have chilliness yet?
Channing
WBCCI# 30676
08-02-2014, 02:34 AM
Moscow
, Idaho
We have reached chill status! Thank you all for the emotional and educational support.
It took all day but the fridge is working like a dream.
Thank you again for your tolerating my noobness.
-C
08-02-2014, 06:49 AM
1999 34' Excella
Hillsboro
Glad it works!!!
Channing
WBCCI# 30676
08-02-2014, 07:26 AM
1966 22' Safari
Hilltop Lakes
Glad it worked!
Now you know the first thing you have to do when you're planning a camping trip with your Airstream. Turn on the fridge a day in advance.
Don't worry, we've all been noobs in the beginning, and most of us still are in areas we've yet to confront. These trailers have myriad ways of challenging us. Also just as many ways to delight us.
