Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 10-14-2018, 09:06 PM   #1
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
no lights on the control panel but it works???
SO my RM-3862 the control panel was not lighting up when I pushed on-off button but the unit still cools.. on lp have not tried elec.
Problem is I have no idea what the temp scale is sitting at. The CLC and LAC light will come on when i push the button for them, but everything else is dark.
Had a bad 3 amp fuse, replaced that. the 5 amp fuse was good.
SO is the board bad or the control panel bad?? how to check to find out. Power is good at 12.7 or more. took board out and checked all connection, reinstalled making sure to push plugs on board firmly and checked to make sure no corrosion or other issues, same with elec terminals on board..
any help welcome.
in the picture it looks like the lights on panel are on but that is from flash.
board does appear to be original, this on a 2005 classic.
ID:	325231   Click image for larger version
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 10-15-2018, 05:12 PM   #2
carl2591's Avatar
2005 31' Classic
so i take the panel off front and check for any burned or loose connections and found everything was OK looking.. anyone have an idea as to what might be the issue. I have checked fuse check the main board.
I have checked everything I can check.. and still get no light on teh left side of the panel. the smaller right side board which controls heaters strips and low ambient control works fine.
you can see the smaller board light are on and the larger board is no lights
Carl, Raleigh NC
Old 10-17-2018, 08:42 PM   #3
carl2591's Avatar
2005 31' Classic
So i thought I found the replacement and sent question to guy on ebay with my info. He was saying that the dometic 2932884014 would not work with my unit
he posted another number 3850408018 was what i needed..
I found one at dyeronline.com and only $74 plus 9 shipping..
http://www.dyersonline.com/dometic-r...-assembly.html
So there you have it the entire event..
thanks for following along and hope this help you if this happens to your unit.
ps
Carl, Raleigh NC
1970 Control Panel Lights on all the time 1970 Safari Electronics & Connectivity 9 02-03-2020 01:39 PM
Running lights working but no brake lights etc. jhuggins76 Lights - Interior & Exterior 16 05-14-2017 09:37 PM
Ok Trailer hook up works but what is this.. Mrcrowley Electrical - Systems, Generators, Batteries & Solar 4 05-28-2007 01:53 AM
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 12:53 AM
New Radio/CD works on 12V but not 110 Austin Runner Electrical - Systems, Generators, Batteries & Solar 3 04-25-2004 07:20 PM
