03-23-2011, 10:17 PM
1965 28' Ambassador
Spokane
, 99201
Newbie needs help
I just purchased my first travel trailer and it had to be a vintage Airstream. 1965 28 foot ambassador. Really good condition but unfortunately the Dometic m52 fridge does not appear to be working, not that I would even really know how to work the thing since it is 17 years older than I am. Also the furnace pilot light is not working while I think I followed the instructions will not seem to work for me. Really wanting to get my toddler out and about in the near future. Can anyone help?
03-23-2011, 11:26 PM
1963 22' Safari
sherman oaks
I can finally weigh in on a subject that I have some knowledge about. After such a lomg time of learning from y'all maybe I can give back... but not that helpful..
I have just restored a '62 Safari with a rm 52 dometic refer and it's toast... A beautiful inside with a beautiful global skin and it lights up on propane wonderfully but there is no gas in the heating system in the rear of the appliance and therefore no cooling.
I have not been able to find anyone that can fix that model and everyone says I need to replace it totally with a new refer. I'm reluctant to just give up and pull that baby out and junk it...
Someone help us!
03-24-2011, 05:43 AM
Retired.
, At Large
03-24-2011, 05:57 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I believe you can purchase the new/rebuilt cooling units and install them yourself while retaining the original vintage fridge.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
03-24-2011, 06:35 AM
Mantua
, Ohio
Make sure the lp tanks are not too low and turned on. Sometimes when the lp is low on fuel it makes for problems. zz
03-24-2011, 07:05 AM
1964 26' Overlander
Richmond
, Virginia
if it's a combo unit, try plugging in the electric and checking then.
03-24-2011, 08:56 AM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Furnace: I've done 4 '70s Airstreams and all the furnaces were rusted beyond use, even though two of them continued to work. Blow the pilot area clean with compressed air. Also, check the pilot flame adjustment on the propane regulator--a small screw that is in the face of the regulator, w/o any indication of what it is.
Fridge: Also blow this area out. There is a flame adjustment on the regulator, also. Plus, check that the flame is impinging on the thermocouple. The thermocouple is the second thing to replace after you've blown the area clean and it's still not working.
Right above the pilot/burner area there is an approximately 2-1/2" diameter vertical tube. Inside this tube is the pipe where the amonia is heated. When you're on electric, there is a 75-120 Watt resistive heater (it varies in Wattage between fridge models) inside the tube that takes the place of the burner heat. There is an access panel in the side of the tube that allows you to replace this item.
Try your fridge on electric--if the tube is warm (give it a few minutes), the fridge should start working within a few hours. It takes quite some time for this to happen. This will give you a chance to figure out whether the basic amonia system is still intact. If so, you can then concentrate of further repair of the propane side.
Zep
03-25-2011, 05:05 PM
1963 28' Ambassador
Northern VT
, Vermont
With a rig of this age you should start at the propane supply. Check pressure and volume, without that correct all else is hopeless, and dangerious. 1st, do'es any appliance have propane? If yes check the lines / connections for leaks. Use a common spray bottle with soap / water solution. With tank valves open & appliances off start misting lines at the tanks working back looking for bubbles. If OK or fixed next check pressure. Fridges are very finicky about pressure. To do this you need a magnometer. Pricey little tool to buy, but very easy to make. Would make a long boring post, google it up. In generall you need 3 ft of 3/8 vinyl tubing, a board, few nails, a ruler & pen. If, BIG IF, the tank regulator funtions properly the magnometer will let you adj the tank regulator to the column inches of pressure required by all appliances in your system. With the pressure. & volume up to snuff you can tackle repair on the fridge & furnace and expect results. Good news is most old fridges can work D.I.Y. Bad news is often old furnaces are wasted internally.
03-25-2011, 05:37 PM
Sioux Falls
, South Dakota
@ ---> blanbowski
My trailer was like Christmas in reverse. Everything I opened, something was taken away. In the end, nothing worked except the water pump and the converter and I think I'll replace those just to not loose the momentum. My trailer was a 20-20. Everything looked pretty good from 20 feet away going 20 miles per hour.
My Airscream experience has been more of a forensic exercise than a restoration. I expect to have a few more surprises before I'm ready to try this trailer on the road. My blog carries a photo record of my misery.
03-25-2011, 05:52 PM
1974 Argosy 26
Morrill
, Nebraska
Level is important
The first thing is to make sure the refer is level. Place a level on the floor of the freezer and check it from side to side and front to back. It's most critical that it be level from the left side to the right side inside the freezer.
Then as noted previously, put it in the electric mode (making sure you have 120 volt AC power to the Unit) set the thermostat at 5. Let it set for 24 hours and see what happens.
