Old 12-24-2007, 07:19 AM   #1
1976 31' Sovereign
Lindenhurst , New York
Newbie Needs Advice - 76 Sovereign
Just starting a winter project, the interior of a 76 Soverign. If I'm building all new cabinets anyway, would the Norcold 3 way 59 7/8 high refrigerator be a good choice. Any suggestins would be appreciated.
Also, need nfo on replacing roof vent. What to buy, where to buy etc.
Thank you.
VinceGrande is offline   Reply With Quote
Old 12-24-2007, 07:24 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Thank you.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Michelle TAC MT-0
Sarah, Snowball
Old 12-24-2007, 07:45 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are rebuilding from scrach consider getting the installation manual for your ref. Most manufactures require a 1 in. MAX clearance behind the ref.
I installed a sheet metal wall behind the ref. to attempt to meet the convection requirements across the coils. This is an easy task while rebuilding.
I also padded the side walls of the enclosure with insulation covered with a thick plastic sheet to produce a air tight fit, a pillow. This is to insure the side walls of th ref, do not see the increased temperature of the heated area behind the ref.
During the summer months if you touch the wall behind the dinette it will be hot.
Name:	lower sheet metal.JPG
2004 Excursion 4x4
Old 12-24-2007, 08:06 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You may want to keep an eye on this thread:
http://www.airforums.com/forums/f455...tml#post494168
TN-TUNDRA is going to be replacing one of his vents very soon...
Richard
Old 12-24-2007, 08:33 AM   #5
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
one other point about refrigerator location;
it's preferable to have the refrigerator located on the awning/shaded side of the trailer because you don't want heat building up behind the refrigerator. i know it's not always possible and i'm not sure if airstream follows that guidline to a tee, but it is something to think about.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Newbie Advice Please nana's ride Member Introductions 11 04-15-2007 07:32 PM
Newbie needs advice/help nmbryant Member Introductions 3 07-08-2006 10:25 AM
Advice for a newbie catalystx2 General Repair Forum 5 08-03-2005 09:57 PM
newbie needs advice chipw Our Community 25 10-09-2004 05:10 AM
Newbie needs your advice mopar7 2004 Safari 25 01-17-2004 08:04 PM
